Help with LED's
PanicMode
Well im new to the forum, and i hope you guys can help me out since im a noob when it comes to LED's.
I need to connect 5 LED's in parallel to a 12v source.
The LED's specifications are as follows:
yellow forward voltage 2.1
20mAMP current
12 V source.
I bought 100oHm 1/4 watt resistors, but when i connected them in series the resistor got really hot.
I dont know what i did wrong or if this is normal for the resistor.
Any help is greatly appreciated.
12V source - 2.1 V forward voltage = 9.9V
I = 20 mA or .02 A
V = IR or R = V/I
R = 9.9/.02 = 495Ω
Replace the 100 Ω resistors with 500 Ω and they should not get hot.
When you had the 100 Ω resistors the current through them was:
V/R = I = 9.9/100 = .099 A or 99 mA.
P = IV so P = .099*9.9 = .9801 W That's almost 4 times what a 1/4 W resistor is rated for.
The 500 Ω resistor will dissipate only about .196 W
20mAMP current
12 V source.
You need to put the LEDs in SERIES (not parallel)!!!
you likely used the SERIES calculator on the web link you provided, which comes up with close to a single 100Ω resistor in SERIES with the five LEDs.
The power dissipation in the resistor will drop to (12-(5*2.1))*0.02 = 30mW, which is well within its 250mW rating. It won't even feel warm...
