Help with C18 and Pointers
bryan
All:
Would appreciate some help with c ,in particular C18. I want to pass a variable to a function via an argument. The function would modify the value of the variable, BUT I don't want to just modify the variable inside the function, but the original variable itself, if you know what I mean. I believe I need to be using pointers, but lost on them. To simplify what I am trying to achieve consider the following.
Function foo simply accepts a int variable and changes it to 10 then could do some additional changes to variable j. The original variable is declared and then passed as the variable a, but I want the value of variable a to be changed every time the function foo process a change to variable j.??
void foo(unsigned int j)
  j=10;
//do something else
//do something else
  return;
void main()
    int a=1;
    foo(a);
I think I need to be doing something like this using pointers but it fails to compile.
void foo(unsigned int *j)
  j=10;
//do something else
//do something else
  return;
void main()
    int a=1;
    foo(&a);
  • Like
Reactions: 3v0
Surely you don't need to use pointers for that?
I haven't got a compiler up on this machine yet, but what would be wrong with something like this:
  j=10;
//do something else
//do something else
  return j;
void main()
    int a=1;
    a = foo(a);
Hmm, it will change the value of j to 10, but not going to change the value of the passed variable a. a will still equal 1.
Sorry BBE you are right, thought you just copied my code from above. a=foo(a) would work, but it is not what I want to do.
bryan
*V gives you the value stored at the address contained in V
&V gives you the address of the variable V
I expect the line in bold is what you are after but I included the use of cptr for contrast. Or maybe just confusion.
char c;
char *cptr = &c;  // this means cptr is a pointer to a char at the address used by c, a pointer to c
void doIt(char* x)  // parm x is a pointer to a character
  *x='z';                   // set the char pointed to by x to 'z'
///////////////////////// Main ////////////////////////
void main()
  c = 'a';
[B]  doIt(&c);    // pass c's address[/B]
  c = 'b';
  doIt(cptr);   // pass a pointer with c's address
This is ok but see the next post
C18 uses pointers exactly as used in the "HowSTuffWorks" example.
They passed pointers to 2 parameters and I passed 1.
I know this can be confusing but it is not too bad once you get it. Let me try again in its most simple form. Lets look at the call first.
// In short instead of passing parameter myVar we pass its address &myVar.
void  doIt(char* localParm) ;  // function prototype
void main()
  char myVar;
  doit(&myVar);  // &myVar is a pointer to myVar (its address)
//because &myVar is a pointer to a char we write the function with that in mind
void  doIt(char* localParm) // char* means pointer to char
   *localParm = 'z';  // localParm's value is the address of myVar so writing ot *localParm is the same as writting to the myVar
Try any of these examples in the simulator and they should work.
Maybe it would be better just to fix yout example in that you were nearly there.
void foo(unsigned int* j)
  [B]*j=10;[/B] //change what *j points to, rather then j itself
//do something else
//do something else
  return;
void main()
    int a=1;
    foo(&a);
Thanks 3v0. Looks like I am on my way with your help. Pointers are one of those things that seem so confusing, but when you actually start to use them they start to make sense. Appreciate your help.
