Help to convert to Anode Display for a 50 V DC Panel Meter...
Hello All
I got this code from internet. Its a good volt meter circuit, I tested. Simple and Locally avilable components. But the code for the Common Cathod Display. Can you someone help to convert it to Common Anode?
And this is the code...
; 18/01/2013
; Çàãîëîâîê ê ïðîãðàììå òðåõñåãìåíòíîãî àìïåð/âîëüòìåòðà
; ñ âíåøíèì ïåïåêëþ÷àòåëåì ðåæèìà èçìåðåíèÿ.
Dev_Freq   EQU   D'4000000'   ; Device Frequency is 4 MHz
RESET_V       EQU   0x0000   ; Address of RESET Vector
ISR_V       EQU   0x0004   ; Address of Interrupt Vector
PMEM_END   EQU   0x03FF   ; Last address in Program Memory
#define   SKIP_IF_ZERO   btfss   STATUS,Z
#define   SKIP_IF_NOZERO   btfsc   STATUS,Z
#define   SKIP_IF_POSITIVE   btfss   STATUS,C
#define   SKIP_IF_NEGATIVE   btfsc   STATUS,C
;======== ÎÏÐÅÄÅËÅÍÈß =====================
;#define       k   .49   ;çíà÷åíèå êîððåêöèè Ò0 äëÿ F=50 Ãö
#define       k   .153   ;çíà÷åíèå êîððåêöèè Ò0 äëÿ F=100 Ãö
;ÍÀÇÍÀ×ÅÍÈß ÄËß ÏÎÐÒÎÂ: RA0-âõîä ÀÖÏ; RA3-âõîä ñ ïåðåêëþ÷àòåëÿ
;âñå îñòàëüíûå - âûõîäû, ïîäòÿæêè âûêëþ÷åíû.
;Ïðè íàçíà÷åíèè ïîðòà RC2 êàê âõîä - òî÷êà ãàñèòñÿ
;Ðåçóëüòàò ÀÖÏ - 2-áàéòíûé
#define TRIS_A       b'00001001'   ;
#define TRIS_C_dot_ON   b'00000000'
#define TRIS_C_dot_OFF   b'00000100'
#define SW_SENSE   PORTA,3   ;âõîä ïåðåêëþ÷àòåëÿ ðîäà ðàáîò
#define DIGIT_1       PORTC,4   ;êàòîä ñòàðøåãî ðàçðÿäà èíäèêàòîðà
#define DIGIT_2       PORTC,3   ;êàòîä ñðåäíåãî ðàçðÿäà èíäèêàòîðà
#define DIGIT_3       PORTC,2   ;êàòîä ìëàäøåãî ðàçðÿäà èíäèêàòîðà
;============ ÏÅÐÅÌÅÍÍÛÅ =========================================
   cblock   0x020
   TEMP       ; TEMPorary register
   COUNTER       ;îáùèé ñ÷åò÷èê
   COUNT       ;ñ÷åò÷èêè çàäåðæåê
   COUNT1       ;
   CCOUNTER   ;ñ÷åò÷èê ïðåðûâàíèé
   D1   ;Ðàçðÿäû èíäèêàòîðà
   D2
   D3
;ðåãèñòðû äëÿ äâîè÷íî-äåñÿòè÷íîãî ïðåîáðàçîâàíèÿ
   DH   ;÷èñëî äëÿ ïðåáîðàçîâàíèÿ bin2bcd
   DL
   ADD_L   ;íàêîïèòåëü ñóììû
   ADD_H
   LED0   ;ðåçóëüòàò ïðåîáðàçîâàíèÿ
   LED1
   LED2
   LED3
   LED4
   INDEX   ;óêàçàòåëü äëÿ èíäèêàöèè
   WREG_TEMP   ;storage for WREG during interrupt
   STATUS_TEMP   ;storage for STATUS during interrupt
   PCLATH_TEMP   ;storage for PCLATH during interrupt
   FSR_TEMP   ;storage for FSR during interrupt
   FLAGS       ;ôëàãè îáùèå
   endc
#define   mode   FLAGS,0   ;,áèò ðåæèìà ðàáîòû U=1, I=0
;ÎÏÐÅÄÅËÅÍß ÄËß ÈÍÄÈÊÀÖÈÈ
;Ñîîòâåòñòâèå ñåãìåíòàì: PORTA '--ABiCGi'; PORTC '--F123ED'
#define coma   PORTC,2   ;áèò âêëþ÷åíèÿ çàïÿòîé
;**** Ì À Ê Ð Î Ñ Û ****
;Ìàêðîñ ïðîèçâîäèò èíêðåìåíò äâóõáàéòîâîãî ÷èñëà NH,NL
INC2B   MACRO   NH,NL   ;ñòàðøèé áàéò, ìëàäøèé áàéò
   clrf   TEMP   ;èíêðåìåíò
   movlw   1   ;2-õ áàéòîâîãî
   addwf   NL,F   ;÷èñëà
   rlf   TEMP,W   ;
   addwf   NH,f   ;
   ENDM
Bank0       MACRO           ;macro to select data RAM bank 0
       bcf   STATUS,RP0
       ENDM
Bank1       MACRO           ;macro to select data RAM bank 1
       bsf   STATUS,RP0
       ENDM
[end code]
Thanking you ....
I thought you were done.....
I just success in compilation only. But its only common cathod. its working good.
But I need to do with common Anode display. I try much times..
I just change to -
       retlw   b'11101011'   ;   ( b'00010100' ; for 1 : this is the original code)
[code end]
I just invert all binary number like that...
But nothing in the display (display OFF.
any other change I can do?
schematic?
I just invert the avmeter.asm and avmeter.h files. (Invert all the binary number. is it okey or can I do change in the opcode too?
The schematic helps a lot... Thank you.
I believe these are the relevant code sections for the 3-digit display;
LEDTABLE_A
        addwf   PCL,F           ;    --AB-CG- on PORTA
        retlw   b'00110100'     ; 0  --AB-C--
        retlw   b'00010100'     ; 1  ---B-C--
        retlw   b'00110010'     ; 2
        retlw   b'00110110'     ; 3
        retlw   b'00010110'     ; 4
        retlw   b'00100110'     ; 5
        retlw   b'00100110'     ; 6
        retlw   b'00110100'     ; 7
        retlw   b'00110110'     ; 8
        retlw   b'00110110'     ; 9
        retlw   b'00000010'     ;'-'
LEDTABLE_C
        addwf   PCL,F           ;    --F---ED on PORTB
        retlw   b'00100011'     ; 0  --F---ED
        retlw   b'00000000'     ; 1  --------
        retlw   b'00000011'     ; 2
        retlw   b'00000001'     ; 3
        retlw   b'00100000'     ; 4
        retlw   b'00100001'     ; 5
        retlw   b'00100011'     ; 6
        retlw   b'00000000'     ; 7
        retlw   b'00100011'     ; 8
        retlw   b'00100001'     ; 9
        retlw   b'00000000'     ;'-'
DISPLAY
        movlw   b'00011100'     ; cathodes K1(RC4),K2(RC3),K3(RC2) off
        movwf   PORTC           ; segments D(RC0),E(RC1),F(RC5) off
        clrf    PORTA           ; segments G(RA1),C(RA2),B(RA4),A(RA5) off
        Bank1                   ;
        movlw   TRIS_C_dot_OFF  ;
        movwf   TRISC           ; K3/DP pin (RC2) off (hi-z input)
        Bank0                   ;
; ïðîâåðÿåì èíäåêñ èíäèêàòîðîâ
; INDEX=0 - ìëàäøèé ðàçðÿä, ïîðò À
; INDEX=1 - ìëàäøèé ðàçðÿä, ïîðò Ñ
; INDEX=6 - ïåðåãðóçêà ñ÷åò÷èêà
        movf    INDEX,W         ; LEDIndex -> W
        sublw   .5              ; in range, 0 <= index <= 5?
        skpc                    ; yes, skip, else
        clrf    INDEX           ; reset index to 0
sel_cathode:                    ; âûáîð îòîáðàæàåìîãî ðàçðÿäà
        movlw   b'00000100'     ;
        andwf   INDEX,W         ; index 4 or 5?
        skpz                    ; no, skip, else
        goto    sel_MSD         ; display most significant digit
        movlw   b'00000010'     ;
        andwf   INDEX,W         ; index 2 or 3?
        goto    sel_CSD         ; display middle digit
sel_LSD
        Bank1                   ; index 0 or 1
        movlw   TRIS_C_dot_ON   ;
        movwf   TRISC           ; make K3/DP (RC2) pin output
        Bank0                   ;
        bcf     DIGIT_3         ; active lo DIGIT_3 (RC2) on
        goto    fire_LSD        ; çàæå÷ü ñåãìåíòû ìëàäøåãî ðàçðÿäà
sel_CSD
        bcf     DIGIT_2         ; active lo DIGIT_2 (RC3) on
        goto    fire_CSD        ; çàæå÷ü ñåãìåíòû ñðåäíåãî ðàçðÿäà
sel_MSD
        bcf     DIGIT_1         ; active lo DIGIT_1 (RC4) on
        goto    fire_MSD        ; çàæå÷ü ñåãìåíòû ñòàðøåãî ðàçðÿäà
; çàæèãàíèå ñåãìåíòîâ èíäèêàòîðà
fire_LSD
        btfss   INDEX,0        ; âûáîð ÷åòâåðêè ñåãìåíòîâ äëÿ îòîáðàæåíèÿ
        goto    fire_LSD_A     ;
fire_LSD_C
        movf    D3,W           ; digit 3, 0..9
        call    LEDTABLE_C     ; get segments D/E/F
        iorwf   PORTC,F        ; put on RC0/RC1/RC5
        goto    display_end    ;
fire_LSD_A
        call    LEDTABLE_A     ; get segments G/C/B/A
        movwf   PORTA          ; put on RA1/RA2/RA4/RA5
        goto    display_end    ;
fire_CSD
        goto    fire_CSD_A     ;
fire_CSD_C
        movf    D2,W           ; digit 2, 0..9
        btfss   mode           ; display decimal point? yes, skip, else
        goto    display_end    ; branch (finish up)
        Bank1                  ; äà, çàñâå÷èâàåì òî÷êó âî 2-ì ðàçðÿäå
        movlw   TRIS_C_dot_ON  ; display decimal point
        movwf   TRISC          ; K3/DP pin (RC2) on (output)
        Bank0                  ;
        bsf     coma           ; turn on K3/DP (RC2) anode
fire_CSD_A
        goto    display_end    ;
fire_MSD
        goto    fire_MSD_A     ;
fire_MSD_C
        movf    D1,W           ; digit 1, 0..9
        btfsc   mode           ; display decimal point? yes, skip, else
        Bank0                  ;
        goto    display_end    ;
fire_MSD_A
        goto    display_end    ;
display_end
        incf    INDEX,F        ; bump index 0..5 -> 1..6
        RETLW   0              ;
Quite a few changes are necessary. I have not looked at the single digit LED 'A' / 'V' display, yet. More later...
Cheerful regards, Mike
Here's my untested first attempt (below). Caveat... There may be errors... I have not had a chance to see if it even assembles correctly.
All of the changes are in the "DISPLAY" section (the two LED segment tables are unchanged).
More later. Mike...
;  display refresh function for Common Anode displays
DISPLAY
        movlw   b'00100011'     ; anodes K1(RC4),K2(RC3),K3(RC2) off
        movlw   b'00110110'     ;
        movwf   PORTA           ; segments G(RA1),C(RA2),B(RA4),A(RA5) off
        movlw   TRISC           ;
        movwf   FSR             ; setup indirect access to TRISC
        movlw   b'00000100'     ; K3/DP pin (RC2) off (hi-z)      |b0
        movwf   INDF            ; trisc = '00000100' RC2 input    |b0
;  select and display digit 1, 2, or 3 based on INDEX 0..5
        movf    INDEX,W         ; LEDIndex -> W                   |b0
        sublw   .5              ; in range, 0 <= index <= 5?      |b0
        skpc                    ; yes, skip, else                 |b0
        clrf    INDEX           ; reset index to 0                |b0
        btfsc   INDEX,2         ; index 4 or 5? no, skip, else    |b0
        goto    sel_MSD         ; display digit 1                 |b0
        btfsc   INDEX,1         ; index 2 or 3? no, skip, else    |b0
        goto    sel_CSD         ; display digit 2                 |b0
sel_LSD
        movlw   b'00000000'     ; K3/DP (RC2) pin 'output'        |b0
        movwf   INDF            ; trisc = '00000000' RC2 output   |b0
        bsf     DIGIT_3         ; active hi DIGIT_3 (RC2) 'on'    |b0
        btfss   INDEX,0         ;
        goto    fire_LSD_A      ;
fire_LSD_C
        movf    D3,W            ; digit 3, 0..9                   |b0
        call    LEDTABLE_C      ; get segments D/E/F              |b0
        xorwf   PORTC,F         ; clr active lo D/E/F segments    |b0
        goto    display_end     ;
fire_LSD_A                      ;
        call    LEDTABLE_A      ; get segments G/C/B/A            |b0
        xorwf   PORTA,F         ; clr active lo G/C/B/A segments  |b0
        goto    display_end     ;
sel_CSD
        bsf     DIGIT_2         ; active hi DIGIT_2 (RC3) 'on'    |b0
        btfss   INDEX,0         ;
        goto    fire_CSD_A      ;
fire_CSD_C                      ;
        movf    D2,W            ; digit 2, 0..9                   |b0
        btfsc   mode            ; dec pt? no, skip, else          |b0
        bcf     INDF,2          ; trisc = '00000000' RC2 output   |b0
fire_CSD_A
        goto    display_end     ;
sel_MSD
        bsf     DIGIT_1         ; active hi DIGIT_1 (RC4) 'on'    |b0
        btfss   INDEX,0         ;
        goto    fire_MSD_A      ;
fire_MSD_C                      ;
        movf    D1,W            ; digit 1, 0..9                   |b0
        btfss   mode            ; dec pt? no, skip, else          |b0
        goto    display_end     ;
fire_MSD_A
display_end
        retlw   0               ;
Thanks MIKE...
Its really amaze me... Thank you so much.
Your code working very correct.. Thanks for the complete code.. I will study your code for my future use.... Thanks again.... Chears..
Good. Happy to help. Please post a picture of your project and don't be afraid to hit the 'like' button on my post...
<added>
I combined the <avmeter.h> and the <avmeter(ca).asm> files into a single file called AVMeter_CA.asm, attached below...
Mike One problem, I detect..
In your programme, Last Digit, segment 'd' and 'f' have some error.. But Proteus simulation is 100% OK....
Please check your code again...
Thanks you..
