Help on Xtal oscillator connections
aduri
Can you help me to recognize the pins of this 12,8MHz oscillator NSA0260B.
Ground is connected to metallic case and there are 3 pins.
It was used as oscillator in telephony.
Is the frequency output at TTL level?
Thank you
I suggest looking up a datasheet for the manufacturer of the oscillator. It doesn't have to be the exact model, any should do assuming that the manufacturer uses the same pinout for each one.
