help needed for configuring only one analog input pin in PIC 16F877A
amit_kr
i m using PIC 16F877A for my project ...i want to use only one pin AN0 for analog input ...i m using SourceBoost IDE c compiler to programme the microcontroller....plz help me to configure it ...
ADC configure code for all analog inputs ....
void init_adc(void){
volatile bit adc_on @ ADCON0 . ADON; //AC activate flag
set_bit(adcon1, ADFM); // AD result needs to be right justified
// set_bit(adcon1, PCFG0); // all analog inputs
// set_bit(adcon1, PCFG1); // Vref+ = Vdd
// set_bit(adcon1, PCFG2); // Vref- = Vss
set_bit(adcon0, ADCS1); // Select Tad = 32 * Tosc (this depends on the X-tal here 10 MHz, should work up to 20 MHz)
clear_bit(adcon0, CHS0); // Channel 0
clear_bit(adcon0, CHS1); //
clear_bit(adcon0, CHS2); //
adc_on = 1; // Activate AD module
i want to use only one input AN0.....what changes have to made in the code
Can't help you with C, but my PIC assembler analogue tutorial explains about the different register settings, in a somewhat more easily understandable fachion than the datasheet - you should be able to get all you need from that!.
what compiler are you using? If PIC's C18, there are a lot of prewritten libraries for ADC and all other functions that are quite handy
