hi,,
i have a problem in a PIC project about "alarm clock" using pic 16F84a.
so iam really Need help, plz.
I am new and have never used PIC before, but no time to learn, i need to get this project running in 1 month.
But i do have basic knowledge in electronics and programming.
my basic problem that i can't learn microC language and do the project in 1 month, so i need someone to transform this program form Basic microC to MicroC as fast as possible .
plz plz guys .. i will be thanksful, if anyone help me
' PIC16F84A ALARM CLOCK
' feel free to use this code at your own risks
' target : PIC16F84A, 16 Mhz crystal
' HS clock, no watchdog.
' Author : Bruno Gavand, September 2007
' see more details on ****Link deleted***
program alarmClock
' if you are using COMMON CATHODE LED display, uncomment this definition.
' if you are using COMMON ANODE LED display, comment this definition.
'#define CATHODE_COMMUNE
symbol LUNDI = 0 ' monday
symbol MARDI = 1 ' thuesday
symbol MERCREDI = 2 ' wednesday
symbol JEUDI = 3 ' thursday
symbol VENDREDI = 4 ' friday
symbol SAMEDI = 5 ' saturday
symbol DIMANCHE = 6 ' sunday
symbol LMMJV = 7 ' from monday to friday included
' alarm definitions, to be changed on your needs
symbol NBALARM = 16 ' number of programmed alarms
const alarmTable as byte[NBALARM * 4] = (
' JOUR HEURE MINUTE DUREE (secondes, 59 maxi)
' DAY HOUR MINUTE DURATION (in seconds, max is 59)
LUNDI, 8, 30, 10,
LUNDI, 12, 30, 10,
LUNDI, 14, 00, 10,
LUNDI, 16, 30, 10,
MARDI, 8, 30, 10,
MARDI, 12, 30, 10,
MARDI, 14, 00, 10,
MARDI, 16, 30, 10,
JEUDI, 8, 30, 10,
JEUDI, 12, 30, 10,
JEUDI, 14, 00, 10,
JEUDI, 16, 30, 10,
VENDREDI, 8, 30, 10,
VENDREDI, 12, 30, 10,
VENDREDI, 14, 00, 10,
VENDREDI, 16, 30, 10
dim maxcount as word ' number of TMR0 overflow per second
dim scaler as word ' RTC scaler
dim jj as byte ' day of week, 0 is monday
dim hh as byte ' hour
dim mn as byte ' min
dim ss as byte ' sec
dim digiled as byte[4] ' 4 x 7 segment table
dim digit as byte ' number of current digit to be displayed
dim dp as byte ' decimal point
dim key as byte ' key code
dim alarm as byte ' alarm flag
' the ISR works as real time clock
sub procedure interrupt
dim i as byte
' count time
scaler = scaler + 1
if scaler > maxcount
then
scaler = 0
inc(ss)
if ss = 60
then
ss = 0
inc(mn)
if mn = 60
then
mn = 0
inc(hh)
if hh = 24
then
hh = 0
inc(jj)
if jj = 8
then
jj = 1
end if
end if
end if
end if
end if
' LED display
#ifdef CATHODE_COMMUNE
PORTA = PORTA and $f0
TRISA = $0f
key = PORTA
TRISA = 0
PORTB = 0
#else
PORTA = PORTA or $0f
TRISA = $0f
key = PORTA
key = not(key)
TRISA = 0
PORTB = $ff
#endif
key = key and $07
digit = digit + 1
if digit > 3
then
digit = 0
i = $01
else
i = $01 << digit
end if
PORTB = digiled[digit]
PORTA = PORTA or i
#else
PORTB = not(PORTB)
PORTA = PORTA and not(i)
#endif
INTCON.T0IF = 0
end sub
' converts digit to 7 segment
sub function intTo7seg(dim n as byte) as byte
select case n
case 0 result = $3F
case 1 result = $06
case 2 result = $5B
case 3 result = $4F
case 4 result = $66
case 5 result = $6D
case 6 result = $7D
case 7 result = $07
case 8 result = $7F
case 9 result = $6F
end select
end sub
' select a value with keys
' value is pointed to by v, display char s as header, maximum value is max
sub procedure setValue(dim v as ^byte, dim s as byte, dim max as byte)
digiled[0] = s
digiled[1] = 0
while 1
if key.0
then
inc(v^)
if(v^ > max)
then
v^ = 0
end if
end if
if key.1
then
if(v^ = 0)
then
v^ = max
else
dec(v^)
end if
end if
if key.2
then
Delay_ms(50)
while key.2
wend
Delay_ms(50)
scaler = 0
ss = 0
return
end if
digiled[2] = intTo7seg(v^ / 10)
digiled[3] = intTo7seg(v^ mod 10)
delay_ms(300)
wend
end sub
' program entry
main:
dim i as byte
' init variables
dp = 0
hh = 0
mn = 0
ss = 0
jj = 0
maxcount = 15625
' init I/O
PORTA = %00010000
TRISA = %00000000
PORTB = 0
TRISB = $00
' init interrupts
INTCON = %10100000
OPTION_REG = %11011000
Delay_ms(50)
' clock adjustment
setValue(@hh, 116, 23)
setValue(@mn, 55, 59)
setValue(@jj, 14, 6)
' forever loop
while true
if key
then
' display day and seconds (what for ? don't remember !)
digiled[0] = intTo7seg(jj)
digiled[1] = 0
digiled[2] = intTo7seg(ss / 10)
digiled[3] = intTo7seg(ss mod 10)
else
' display hours and minutes
if hh < 10
then
digiled[0] = 0
digiled[1] = intTo7seg(hh)
else
digiled[0] = intTo7seg(hh / 10)
digiled[1] = intTo7seg(hh mod 10)
end if
digiled[2] = intTo7seg(mn / 10)
digiled[3] = intTo7seg(mn mod 10)
end if
' blinks semicolon (or decimal point)
if scaler > maxcount / 2
then
dp.1 = 1
else
dp.1 = 0
end if
' set decimal points
digiled[0].7 = dp.0
digiled[1].7 = dp.1
digiled[2].7 = dp.2
digiled[3].7 = dp.3
' check for alarm condition
alarm = 0
for i = 0 to (NBALARM - 1) * 4
if ((alarmTable[i] = jj) or ((alarmTable[i] = LMMJV) and (jj < SAMEDI)))
and (alarmTable[i + 1] = hh)
and (alarmTable[i + 2] = mn)
and (alarmTable[i + 3] > ss)
then
inc(alarm)
end if
next i
if alarm
then
' set alarm
dp.3 = 1
PORTA.4 = 0
else
' clear alarm
dp.3 = 0
PORTA.4 = 1
end if
wend
end.
