Help in building project in MPLAB C18 C compiler for PIC18f452
stupidalbert
Hi, I'm new to PIC18f452 and I want to build a project using MPLAB IDE v8.00 and I've installed the MPLAB-C18-Std-Eval-v3_33 as well. I'm using ICD2 as the loader.
When i was trying to build the project, I followed the instructions from MPLAB C18 C Compiler Getting Started but it didnt' work. It shows the following messages when I Build All/Make the project:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\My project\albert.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPLAB IDE\Core\MPLAB.exe" -p=18F452 /i"C:\MCC18\h" "C:\MCC18\example\getting_started\program1\main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" /l"C:\MCC18\lib" "C:\Program Files\Microchip\MPASM Suite\LKR\18f452.lkr" "C:\My project\main.o" /m"albert.map" /w /o"albert.cof"
MPLINK 4.14, Linker
Copyright (c) 2007 Microchip Technology Inc.
Error - could not find file 'C:\My project\main.o'.
Errors : 1
Link step failed.
BUILD FAILED: Thu Oct 08 14:43:29 2009
Can somebody give me some suggestions to build a project.
I just made a project with this as the main code,
#include <p18f452.h>
#pragma config WDT = OFF, LVP = OFF, OSC = HS, DEBUG = OFF
void main(void){
char i;
    ADCON1=0x07;
    while(1);
I didn't add a linker script and it compiles fine.
Thx Mike,
when i tried to use the simple example code "Hello World" to compile and build project. It doesn't work and show the messages.
