HELP FOR DIRECTIVES
HAMZAZAYYAD
HOW CAN I USE ADIRECTIVES LIKE WHILE , IF ,AS AN INSTRUCTION
HELPFUL IN APROGRAMLIKEAN EXAMPLE:
WHILE PORTA,1==0
GOTO LOOP5
ENDW
LOOP5
BCF PORTB,3
WHILE PORTA,1==0
GOTO LOOP5
ENDW
LOOP5
BCF PORTB,3
Use BTFSS or BTFSC - have a look on the PICList for examples of various control structures using them!.
To use high level directives like while/wend you need a higher level language. Have a look at the free to use **broken link removed** or **broken link removed**. This may help you.
Personally, I'd try to learn assembler. Have a look at .
how can i use two sub prog
hi
i need help
linker
CODEPAGE NAME=vectors START=0x0 END=0x1F PROTECTED
CODEPAGE NAME=page START=0x20 END=0x3FF
when i uses a sub program only, no errors
but when i uses more than one sub program ,this error apear
Copyright (c) 2005 Microchip Technology Inc.
Error - section 'INT_VECTOR' can not fit the absolute section. Section 'INT_VECTOR' start=0x00000000, length=0x0000005a
Errors : 1
BUILD FAILED: Mon Jun 06 14:59:42 2005
whats wrong??
my program USES PIC16F84A WITH ASSEMBLY ,MPLAB
SUB PROGRAM
RETURN
SUB PROGRAM1
RETURN
SUB PROGRAM2
RETURN
MAIN CODE
start
call SUB PROGRAM1
call SUB PROGRAM2
en
It looks like you are trying to assemble code that is written for a PIC18 chip. I think you should read the sticky and look at Nigel's tutorials.
