IjabaFilms
I'm a filmmaker working on a project where I'm trying to build my own production monitor large enough and with a high enough resolution for focus pulling. Sure they sell production monitors but they are a gazillion dollars for the guerrilla filmmaker such as myself.
Anyway, I went on eBay and bought a 15" HDTV that just has a bad inverter. The TV only cost about $30 total.
So I get it and turn it on and the TV comes on and stays on for about 5 minutes then the screen gets black. I shine a light on it and I can see the TV is still on and working. So yes, we have a problem with supplying power to the CCFLs.
With this particular TV (I bought some others but they are easy fixes), I opened it up and saw that it has a PSU board that connects to the mainboard (the other TVs I bought had a DC jack right on the main board so all one has to do is replace the inverter which is a separate unit). This TV has the inverter right on the PSU.
From what I understand of this situation, the portion of the PSU supplying power to the TV is fine but the area designated to run the CCFLs has a problem. I'm thinking of two things here...
1st. I actually would love to do away with the PSU and find a way to put a DC jack on the main board instead and use an AC adapter or 12v battery pack instead. This would be ideal because I have a 12v battery pack and would love to not have to worry if there is an available wall jack in a shooting location.
Then I can just use the 2 light inverter I already bought to fix the backlight problem.
But if doing away with the PSU is not possible, How can I remedy the inverter issue when the inverter is on the board that powers the TV?
The PSU connects to the mainboard via a 14 pin double row right angle header and the mainboard has the female header connector.
Here are photos: (image descriptions are at the bottom of the images)
The yellow board is the PSU.
Any help would be appreciated. I don't know a whole lot about electronics but I have been having a good time learning and I want to know how this all works. From what I was reading, the mainboard accepts 12volts and the PSU converts what comes out of the wall into 12volts??? Am I understanding the point of the PSU correctly?
Thanks!
Thanks!
