Hc 595 4780 LED display
lurkepus
I'm working on a little project using a pic16f628a , hc595 and a 4780 LCD display in 8 bit mode , but i just get a black screen .
i'm not sure if it is a hardware or software problem ..
This is the code i'm using
;*******************HC595 pins****************************************
; Pic pin 17 (DS)to pin 14
; Pic pin 18 (SH)to pin 11
; Pic pin 1  (ST)to pin 12
; 595 Pin 10 16 to +
; 595 Pin  8 13  to  Gnd
#define PIN_q7 PORTA,0 ; DS (serial data in)
#define PIN_SH PORTA,1 ; SH_CP(shift)
#define PIN_ST PORTA,2 ; ST_CP (latch)
#define LCD_RS PORTA,3 ; PIC pin 2 ->LCD RS (pin4)
#define LCD_E  PORTA,4 ; PIC pin 3 ->LCD clock(pin6) 1 to send data
#define R_DEL1            0x20    ; Delay register
#define R_DEL2            0x21    ; Delay register
;LCD INIT
;Boot
Boot
    movlw    0x14
    call    delay
;   LCD INIT 2
INIT
    bcf LCD_E
    BcF LCD_RS
    ;movlw b'00110000'
    ;call _595
    ;call pulse_e
    movlw b'00110000'
    call _595
    call pulse_e
    movlw b'00110000'
    call _595
    call pulse_e
    movlw b'00110000'  ;8 bit operation For 4 bit mode Send command 0010xxxx as one operation (bottom 4 bits are don't care)
    call _595
    call pulse_e
    movlw b'00001111'
    call _595
    call pulse_e
    movlw b'00000111'
    call _595
    call pulse_e
    movlw b'00000001'
    call _595
    call pulse_e
loop
    bcf LCD_RS
    movlw b'00000010'
    nop
    nop
    nop
    bsf        LCD_RS
    call delay_1ms
    movlw 'a'
    call _595
    call pulse_e
loop1
    goto loop1
_595
  movwf data1
   movlW .8
  movwf RXT
d0
        btfsc     data1,7
        bsf   PIN_q7
        btfss   data1,7
        bcf     PIN_q7
        bsf     PIN_SH
        call    delay_1ms
    call    delay_1ms
        bcf     PIN_SH
     rlf data1
  DECFSZ RXT,F
  goto d0
       bsf     PIN_ST
     call    delay_1ms
    call    delay_1ms
        bcf     PIN_ST
  return
pulse_e
    bsf        LCD_E
    nop
    nop
    nop
    nop
    bcf        LCD_E
    call    delay_1ms
    call    delay_1ms
    call    delay_1ms
    return
i just added the code for the 595 and 4780 to make it easy to read but i do have the comparators turned off and the 595 works. tested it using LED's .. I also use a 10k trimpot to adjust the contrast ..
main
CLRF PORTA
MOVLW 0x07
MOVWF CMCON
BCF STATUS, RP1
BSF STATUS, RP0 ;Select Bank1
MOVLW b'01000000'
MOVWF TRISA
MOVLW 0xf0
MOVWF TRISB
BANKSEL PORTA
CLRF PORTA
CLRF PORTB
i did try to swap
LCD_RS PORTA,3 --> PORTB,3
LCD_E PORTA,4 --> PORTB,0
They both have pullup resistors but no luck ...
Just tested the (bit) of code you posted.... With a 10k pullup on RA4 it works well!!
EDIT!!!
I noticed you have named PORTA,0 pin_q7... I know this connects to the DS pin... You haven't connected it to Q7???
sorry about the messy code RA0 (pin 17) is connected to pin 14 (DS) on the 595 .. I i will try to add the pull up resistor and see if that helps i just need to put stuff back on the breadboard first :)btw the loop was just for testing and will be removed as soon as i got things working
i have gone trough the wiring and added the pull up resistor but the display is just looking like this .. could it be a timing issue ?
this is the config settings i'm using not sure if it's the problem
__CONFIG _FOSC_INTOSCIO & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _LVP_OFF & _CPD_OFF & _CP_OFF
