PG1995
Active Member
Hi
It is said that coding the hardware using machine language can greatly enhance speed, efficiency, and such related parameters. I have been told even now when speed, efficiency, etc., are the concerns of importance, then coding of the hardware with assembly or machine language is preferred. I don't get it. Suppose you write a code using C++ to use with a microcontroller. You compile it using a compiler which would render the code into a hex code (machine code). You see you still end up with machine code. The same can be said about assembly language which also gets assembled into machine code but is a low level language. Why is so? Could you please help me with it? Thank you.
Regards
PG
Regards
PG
