Page 19 and 26... of the datasheet respectively..
Deduction..... GP2... Weak pullup... Pulsed input..... The Pic12f6xx has GP2 with T0CK1 input..... The pic12f5xx doesn't have weak pullup on GP2. The pic12f1xxx doesn't have GPIO,
Really its the only chip it can be....
Mike.... Back to the original post..... The data he is seeking... IS in the datasheet.. IF he is using the pic12f6xx the data he needs is on those two pages... I was merely telling him to read it.
Anyway... What tme is it in Michigan.. Shouldn't you be in bed![]()
Ok.. I concede ..... It was from the pic12929.... But all then same.... The info is in there... All that doesn't matter because I think the OP has done one.... (left the building )
Guys I'm getting a 1Hz pulse from an open drain type source. Can I enable weak pull up on GP2 & also enable External Interrupt trigger (High to low Transition)?
Thank you. Your initial replies were not very helpful. Referring to page numbers on some unnamed and out-of-date Datasheet was not only confusing but misleading since there's no way for anyone to know which sections you were referring to.Ian Rogers said:I was sorry to be so vague.
