Get starting with pic18f452
unicorn
Hello everybody
I have a problem with pic18f452 that it I do the follows to test the pic first:
first I use very simple program that outputs high all the time on the port B for example.
but when I measure the voltage on the output port it gives 0v :(
I have run this program with pic16f84 and more other programs on this pic with no problems.
but it is my first time to use 18f452
I think there is problem in my initialization code of the pic
I make the powerup timer = disable
watchdog = disable
brownout = disable
If it is possible to send me link of c samples codes of pic18f452
#include<18f452.h>
#fuses HS,NOWDT,NOPROTECT,NOPUT ,NOBROWNOUT
void main()
while(1)
output_B(255)
you r right it was my fault I didn't copy the original code from the compiler
I wrote it online but the program is ok and build succeeded
That not so 16f84 has two tris register
16F84 doesn't have a TRIS .
TRISA AND TRISB I think you mean it don't take much to set up a 16f84a. The 18fxxx you have to set a lot up .
void main (void)
  /* Make all bits on the Port B (LEDs) output bits.
   * If bit is cleared, then the bit is an output bit.
  TRISB = 0;
  while (1)
      /* Reset the LEDs */
      PORTB = 0;
      /* Delay so human eye can see change */
      delay ();
      /* Light the LEDs */
      PORTB = 0x5A;
      delay ();
This is for the 16f84a
PortA On any device reset, these pins are configured as inputs
PortB unchanged
I get tierd with this pic i don't know where is the wrong help me
this is the circuit
MyPicx.com - circuit
and this is the program
#include<18f452.h>
#use delay(clock=4000000)
void main()
set_tris_b(0);
while(1)
output_b(255);
delay_ms(1500);
output_b(0);
delay_ms(1500);
I use ccs compiler
the problem is there is no output and when I measure the input voltage in the circuit I get 0V
I connect the MCLR(Reset)pin to the VCC
Please help me
Try this and see
#include<18f452.h>
#fuses XT,NOWDT,NOPROTECT,NOPUT ,NOBROWNOUT
#use delay(clock=400000)
void main()
set_tris_b(0);
while(1)
output_b(255);
delay_ms(1500);
output_b(0);
delay_ms(1500);
You are using a 4mhz Crystal/Resonator you set it for 40mhz
and HS is for 8 and 16 mhz
I have tried this code and change the HS to XT,, and get the same previous results
the question is why when I put the voltage source in my circuit and measure it in the circuit it becomes 0V and when I release it from the circuit it returns again to 5V what does this mean??
