Frequency counting using PIC16F876A
vsmGuy
I am trying to make a frequency counter using a PIC16F876A clocked by a 20Mhz XTAL.
The target is to design a system that has a resolution of 1LSB upto 1MHz. It is not necessary though that the PIC achieve this in isolation.
For example, if the PIC can count accurately till 100Khz, I would connect it to a 75HC4059 so that I can divide the original signal before connecting it to the PIC CCP1
Here is the core logic that I have managed so far:
#define START_OF_READING  0
#define MIDDLE_OF_READING    1
#define END_OF_READING   2
#define SAMPLE_COUNT 2
// being explicit about the types ( for quick readability )
unsigned int8 stateOfReading;
unsigned int8 timer1Overflow;
unsigned int16 uiCount, uiCountBefore, uiCountAfter, uiCountStart;
//int1 state = 0;
//#define printf
// Fires when timer1 overflows
#int_TIMER1
void  TIMER1_isr(void)
   ++timer1Overflow;
   //output_bit( PIN_C0, (state = !state));
#int_CCP1
void  CCP1_isr(void)
   output_bit( PIN_C0, state );
   state = !state;
   uiCountStart = get_timer1();
   if ( stateOfReading == START_OF_READING )   // first edge has arrived
      stateOfReading = MIDDLE_OF_READING;
      timer1Overflow = 0;
      set_timer1 ( 0 );     // restart timer on this edge
   else if ( stateOfReading == MIDDLE_OF_READING ) // second edge has arrived
      uiCountBefore = get_timer1();
      uiCount = CCP_1; // get capture value. *Theoretically* should be same as writing iCount = get_timer1(); ( Practically though, it never is even close ? Does the timer1 value get copied into CCP1 AFTER the ISR is serviced )
      uiCountAfter = get_timer1();
      stateOfReading = END_OF_READING;   // prevent further processing during this interrupt
The driver:
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   setup_timer_1( T1_INTERNAL | T1_DIV_BY_4 );
   //setup_timer_1( T1_INTERNAL );
   setup_ccp1( CCP_CAPTURE_RE | CCP_CAPTURE_DIV_4 ); // Configure CCP1 to capture every 4th rising edge\
   //setup_ccp1( CCP_CAPTURE_RE );
   enable_interrupts(INT_TIMER1);
   enable_interrupts(INT_CCP1);
   //enable_interrupts(GLOBAL);
   disable_interrupts( GLOBAL );
   stateOfReading = END_OF_READING; // We don't want to set this to either START_OF_READING or MIDDLE_OF_READING - as that would let the ISR code execute
   unsigned int8 dx = 0;
   while( TRUE )
      unsigned int32 totalTicks = 0;
      for ( dx = 0; dx < SAMPLE_COUNT; ++dx )
         stateOfReading = START_OF_READING; // allow ISR to execute
         enable_interrupts( GLOBAL );
         while ( stateOfReading != END_OF_READING );
         printf ( "[%d] timer1Overflow = %d, uiCount = %Lu/%Lu/%Lu/%Lu\r\n", dx, timer1Overflow, uiCountStart, uiCountBefore, uiCount, uiCountAfter  );
         totalTicks += ( 0x10000 * timer1Overflow ); /* Every overflow -> 65536 ticks */
         totalTicks += uiCountStart;
      printf ( "RAW totalTicks = %Ld\r\n", totalTicks );
      totalTicks /= SAMPLE_COUNT;
Once I connect this to a 100Hz signal, this is what I expect:
100Hz period = 10^4uS
As we have divided timer1 by 4, its resolution is 0.8uS and thus would give 10^4/0.8 = 12500 ticks
The CCP1 ISR being configured to fire after every 4th edge, the timer1 should have 4 times the above value = 4*12500 = 50000 ticks
50k ticks is well below 65536 ticks of timer1 and hence, at this sample freq., timer 1 should never overflow.
This is the output I get once I run my code:
[0] timer1Overflow = 3, uiCount = 3387/3392/3377/3396
[1] timer1Overflow = 3, uiCount = 3387/3392/3377/3396
RAW totalTicks = 399990
As we can see, timer1 overflowed 3 times ( = 3 * 65536 ticks ) and even after that counted up to 3387
This means, the sampling freq. triggered 3 * 65536 + 3387 = 199995 ticks
At 0.8uS for timer1, 199995 ticks = 6.25Hz
This is 16 times less than the actual frequency!
What is going wrong?
  • FreqCounter.hex
If you check MicroChip, there's a VERY, VERY old design in the application notes (20 years old?) for an auto-ranging 50Mhz frequency counter using a PIC clocked at only 4MHz. If you check the PICList there's a slightly more 'modern' (only in the teens) version that uses a 16F84 (or similar) and an LCD display. No need to use any external counters.
I believe that there is a max 40nS limit to timer0 pin which limits the freq. that can be measured by the PIC to 25Mhz?
Do we have any details about the technique of measuring freq. in excess of internal core freq. using the timer0 "self clocking" technique ( input signal is gated and an extra pin is used to clock the prescale register ) on this forum ?
I wanted to read a good writeup on this technique so I could try it out.
I did read the Appnote you are talking about - however, it uses very tightly coded delays that would tie up the PIC completely ( all the PIC would be able to do is measure a freq. while I intend to add more features )
It's 20-nsecs (50-MHz) "with prescaler" in the specs'...
You could capture overflows and gate the T0CKI input via interrupts. Many of us use a 1-msec or 10-msec 'heartbeat' interrupt already for RTC and switch management functions. Just task that for additional functionality.
Regards, Mike
Regards, Mike
I am finding it hard to "get" this thing.
Is these some nice documentation/C code for this?
If I'm reading your posts correctly it seems you want to derive Frequency from measuring the period of a signal (leading edge to leading edge). That's quite a bit different from a frequency counter so I apologize if we've accidentally taken you off track...
:-D
I am thinking of using TIMER1 in asynch mode - any working samples in C to read/start from?
