Flashing LED with PIC16F627
@ Jakes electronics, Thanks for the circuit I have got it to work What kind of voltage does each pin allow out to the component? If i was to create a circuit for a motor would I have to use a transistor?
Rhys
The output will give 5 volts (providing the input is 5 volts) but the I/O pins on a pic can only 'sink' and 'source' up to 25mA. (See section 17 of the datasheet "Electrical Specifications")
Maximum output current sunk by any I/O pin..........................................................................................................25 mA
Maximum output current sourced by any I/O pin ....................................................................................................25 mA
So the answer about having to use a transistor is yes.
Anything over 25mA will need some type of transistor.
That is called Assembly. Or Assembler. (Depends what you read or who you ask lol)
The file extension is .asm
Languages like C compile down to assembly first before being coverted to a .HEX file. (The Hex file being the data written to the chip)
(you'll notice i also provide the .HEX file so if you had a 628A, you could burn that straight to your chip)
C and other lanuages are almost like a "short hand".
Every line of code can be converted to assembly (and does when compiled). But assembly can be heavily condesed by using another languages.
Lets try somethings....
I dont know any other language so I cann't give you an example....
So somebody, please help me out haha....
For those that know assembly AND C, give an example of a snippet of code in each that achieve the same thing.
for example an "If" statement....
1. Power the chip,
2. hold the data input hi or low
3. raise and lower (set and clear) the clock input to shift data bit into chip,
4. Goto step 2
