salim alfarsi
Hi,i have project and i am having difficulties in the programming code.i explain briefly to u my circuit. gas sensor send analog voltage to PIC16F887 microcontroller and MC Display the reading on LCD. in same time the MC will close or shut off solenoid valve to isolate the gas leak. after that MC also will send signal to GSM modem to send SMS to the concerned person informing him by the gas leak.View attachment 60737
and this is my code:
/* --start of comment
* Project name:
LPG Detector
* Description:
A project that detects LPG gas leaks.
* Created By:
Salim
* Version 1.2
01/04/2012
* Version 1
12/17/2011
* Test configuration:
MCU: PIC16F877
Oscillator: 8000000 Hz
SW: mikroC PRO for PIC
-- end of comment */
// Lcd pinout settings
sbit LCD_RS at RB0_bit;
sbit LCD_EN at RB1_bit;
sbit LCD_D4 at RB2_bit;
sbit LCD_D5 at RB3_bit;
sbit LCD_D6 at RB4_bit;
sbit LCD_D7 at RB5_bit;
// Pin direction
sqqqbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB3_bit;
sbit LCD_D6_Direction at TRISB4_bit;
sbit LCD_D7_Direction at TRISB5_bit;
//status LEDs are mapped to sbit variables
sbit GREEN_LED at RE1_bit;
sbit RED_LED at RE2_bit;
void MCU_Init();
void Lcd_Init();
void SendMessage();
void CheckGasSensor();
void UpdateLCD();
void UpdateLEDs();
void SolenoidDisableGas();
//Global sensor status code value
int SENSOR_STATUS_CODE = 0;
//Global gas concentration level
double GAS_CONCENTRATION_LEVEL = 0.0;
void main()
//Set up the MCU
MCU_Init();
//Set up the ADC
ADC_Init();
//Set up LCD screen
Lcd_Init();
Lcd_Out(1, 1, "LPG Detector");
Lcd_Cmd(_LCD_CURSOR_OFF);
//Program Run loop
while(1){
//Check for a sensor reading
CheckGasSensor();
//Update the text on the LCD Screen
UpdateLCD();
//Update the Red and Green status LEDs
UpdateLEDs();
//Shut off the gas if the gas level is dangerous
if(SENSOR_STATUS_CODE == 2){
//Send a GSM message if there is an error
if(SENSOR_STATUS_CODE != 0){
SendMessage();
//Wait a 1/2 second between updates
Delay_ms(500);
void MCU_Init()
//ANSEL = 0x08; // Configure AN5 pin as analog input
//C1ON_bit = 0; // Disable comparators
//C2ON_bit = 0;
//GIE = 1; // Global interrupt is enabled
TRISA = 0xFF; // PORTA is input
TRISE = 0; // PORTE is output
void CheckGasSensor(){
unsigned int temp; //This creates a 10 bit number
temp = ADC_Read(5); // Read the ADC value from ADC Channel 5
Lcd_Out(2,1,text); // Write result in the second line
tlong = (long)adc_rd * 5000; // Convert the result in millivolts
tlong = tlong / 1023; // 0..1023 -> 0-5000mV
ch = tlong / 1000; // Extract volts (thousands of millivolts)
// from result
Lcd_Chr(2,9,48+ch); // Write result in ASCII format
Lcd_Chr_CP('.');
ch = (tlong / 1000) % 10; // Extract thousands of millivolts
Lcd_Chr_CP(48+ch);
ch = (tlong / 100) % 10; // Extract hundreds of millivolts
Lcd_Chr_CP(48+ch); // Write result in ASCII format
ch = (tlong / 10) % 10; // Extract tens of millivolts
ch = tlong % 10; // Extract digits for millivolts
Lcd_Chr_CP('V');
Delay_ms(1);
GAS_CONCENTRATION_LEVEL = (double)temp*0.02; // multiply max ADC value by 0.02 to scale it to 20.48
if( (GAS_CONCENTRATION_LEVEL > 100) && (GAS_CONCENTRATION_LEVEL < 300) ){
//Sets the sensor status code to 1 (warning level)
//if the gas is between 100 and 300 ppm
SENSOR_STATUS_CODE = 1;
else if(GAS_CONCENTRATION_LEVEL > 300){
//Sets the sensor status code to 2 (danger level)
//if the gas is above 300 ppm
SENSOR_STATUS_CODE = 2;
else{
//Sets the sensor status code to 0 (okay)
void UpdateLCD(){
//Check if there are no errors
if(SENSOR_STATUS_CODE == 0){
Lcd_Out(2, 1, "Status: Normal ");
else if (SENSOR_STATUS_CODE == 1){
Lcd_Out(2, 1, "Status:Warning! ");
else if (SENSOR_STATUS_CODE == 2){
Lcd_Out(2, 1, "Status:Gas Off ");
void UpdateLEDs(){
//Status: Normal has the Green LED on
GREEN_LED = 1;
RED_LED = 0;
//Status:Warning has the Red LED blinking
GREEN_LED = 0;
//Toggle Red LED on / off for a blinking effect
if(RED_LED){
RED_LED = 0;
else{
RED_LED = 1;
//Status:Gas Off has the Red LED on solid
GREEN_LED = 0;
RED_LED = 1;
//Shut off the Gas
void SolenoidDisableGas(){
//Disable the gas by turning on a solenoid
//choose PORTA and pin RA0 to controls the solenoid
PORTA.F0 = 1;
void SendMessage(){
UART1_Init(9600);
UART1_Write_Text("AT+CMGS="); //AT+CMGS=
Delay_ms(1000);
UART1_Write(0x22); //"
Delay_ms(2000);
UART1_Write_Text("0060179291471"); // my no
Delay_ms(2000);
UART1_Write(0x22);
UART1_Write(0x0D); //(CR) means Enter
Delay_ms(2000);
UART1_Write_Text("LPG Leak Concentration > 300ppm"); // status text
Delay_ms(2000);
UART1_Write(26); // Ctrl z
Delay_ms(2000);
Delay_ms(2000);
