Hello everyone! This is my first post here as I'm looking for some eletronics help. EE def. wasn't my strong point in college, hence why I became an ME
Please bare with me if this sounds like a simple question.
The task:
On my 21ft boat I'm trying to build a circuit that pulses a signal wire coming off the ignition coil. In other words, if take the negative terminal on the coil and put it to ground, the engine shuts off.
What I'm looking to do is to be able to hold in a N.O. momentary switch while I'm shifting the boat into gear and have the engine stumble (not stall) by pulsing this wire to ground. When I release the switch, the engine should run normally.
I have already mounted the switch near the shifter control and just wired one end to ground and the other end to the neg. side of the coil. Obviously if I hold the switch in for too long, the engine stalls. I can pulse the switch with my finger, but that gets old.... hence the design of the circuit. Would this fall under the oscillating circuit category or something?
Please help. Thanks for your time.
Doug
The task:
Doug
