Firefly 16F88 IR_IN & Button 1 test program
A simple program that lights LED1 Green when an IR signal is detected. Also can be used to test pushbutton #1
; Firefly IR in test and/or button 1 test
; DIP switch dduudd (IR_in on, Tutor on, all others off)
    list      p=16f88             ; list directive to define processor
    include   <p16F88.inc>        ; processor specific variable definitions
    errorlevel  -302              ; suppress message 302 from list file
    __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_ON & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
    __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
; Oscillator select for Firefly 16F88 internal OSC (this also affects USART)
; 0 = 31.25KHz, 1 = 125KHz, 2 = 250KHz, 3 = 500KHz
; 4 = 1MHz,     5 = 2MHz,   6 = 4MHz,   7 = 8MHz
; OSCCON = 0xxx0010 (xxx = speed, bit2 = use internal RC osc)
OSC       EQU         7                 ;enter desired Oscillator speed
; _let macro similar to BASIC LET X = value
; designed for readability
_let      macro     register, literal   ;_let <register>, <literal>
          movlw     literal             ;W = literal
          banksel   register            ;make sure it's in the right bank
          movwf     register            ;register = W
          endm
          org       0x000
          _let      OSCCON, OSC*.16|0x2 ; use OSC value to set internal osc
          _let      CMCON, 0x07         ; disable comparators
          _let      ANSEL, 0x00         ; disable A/D inputs
          _let      OPTION_REG, 0x00    ; weak pullups
          _let      TRISB, b'11111111'  ; all inputs
          _let      TRISA, b'10111110'  ; enable LED 1 (red / green)
          banksel   0                   ;B0 switch to bank 0
          clrf      PORTA               ;B0 zero port (LEDs off)
IR_test   btfss     PORTB, 0            ;B0 is RB0 low?
          bsf       PORTA, 0            ;B0 if yes then LED1 on (Green)
          btfsc     PORTB, 0            ;B0 is RB0 high?
          bcf       PORTA, 0            ;B0 if yes then LED1 off
          goto      IR_test             ; loop forver
          end
Bill,
You're using Microchip instructions opcodes! I can actually understand your program listing (grin)! Thank you!
Happy Holidays. Mike
I'm actually enjoying it more than the old Parallax CVASM16. I can get macros to do things similar to CVASM16. I do like the banksel command and the math is pretty handy. Myke Predko is has recommened not using banksel but I think it's handy as anything if used properly and is recommend by Microchip as when you compile for the 18F series it simply ignores the command.
MPLAB is a teriffic tool for when you get the hang of it. Switching between the simulator, the ICD2 & the programmer is fast and easy. Knowing when to use the Simulator over the ICD2 is the key to speedy debugging.
PS do you like the _LET macro? doesn't hide in the code like a mov instruction would.
PPS Mike, did you manage to finish building your Firefly? Any code snippits you want to share?
