fet configurations
tomas632
hi, just for homework purposes and out of interest could someone explain the different types of fets and how they work?
I am ok with n channel enhancement - current flow from drain to source when a positive gate voltage is applied with respect to the source voltage. could someone explain n channel depletion and p channel enh and depletion?
A depletion N-channel MOSFET behaves like a JugFET, it's normally on and you need a negative voltage with repect to the source to turn it off. The P-channel device is the same but with the polarity reversed.
The difference between a depletion MOSFET and a JugFET is the former has a metal oxide insulating layer between the gate and channel and the latter does not.
Field-effect transistor - Wikipedia, the free encyclopedia
so to clarify...
n channel enh - +ve Vgs to turn fet on, fet is normally off, current from drain to source
n channel dep - -ve Vgs to turn fet off, fet is normally on, current from drain to source
p channel enh - +ve Vgs to turn fet on, fet is normally off, current from source to drain
p channel dep - -ve Vgs to turn fet off, fet is normally on, current from source to drain
is this correct?
Yes, that's correct, assuming conventional current flow.
