Yes, as suspected, the internal clock frequency is 4MHz, the output frequency looks to be that divided by 4096, nothing special required for the transistors.
This doesn't defeate tyour point but the BC107 has a GBWP of only 150MHz.Standard small signal transistors (like the BC107) are rated at 300MHz, and that's an audio transistor.
http://www.datasheetcatalog.org/datasheet/SEME-LAB/BC107.pdf
Man, I'm trying to tell you. Use an Emitter follower NPN. You can use a 2N3904. Transistors switch much faster in common collector configuration. I have done this to drive an LED and it worked so well I swore I would never go back to common emitter LED driver.
Alright,
Thanks again for everyone's assistance so far. I have another question, same topic...
I have tested a PNP powerFET with an LED @ +5v 350mA...
Theory:
0v turns on the LED while +5v turns off the LED.
The issue I face is that the LED is not turning completely on at 0v. I notice slightly more light output when I connect the LED directly to the 4.7Ohm resistor I'm using to limit current, rather than going through the MOSFET.
Attached is the datasheet for the IRF9540n I have.
https://www.electro-tech-online.com/custompdfs/2009/07/irf9540n-1.pdf
Is this because the mosfet is listed as having a Vgs threshold of -2v to -4v?
Alright,
Theory:
https://www.electro-tech-online.com/custompdfs/2009/07/irf9540n-2.pdf
