external interrupt
neelam29
hi
i am trying to make a system including frequency meter. for frequency
measurement method:- measuring time between two consequtive pulses. i'm
feeding the frequency at external interrupt pin. i'm facing a small
problem. when i start the system lcd displays the correct frequency
value. (i've added 5 seconds delay for refreshing the data) but second
time the frequency is refreshed the value comes wrong and after that
everytime absart values are displayed. i've tried everything. i've
tried re-intializing everything but nothing is helping out. here's the
code (the main part which measures freq. and displays it. Please help
me.
Kind regards.
	LIST	p=16F877A, W=2, X=ON, R=DEC	;tell assembler what chip we are using
	include "P16F877A.inc"			;include the defaults for the chip
	ERRORLEVEL	0,	-302		;suppress bank selection messages
	__CONFIG    0x393A			;sets the configuration settings (oscillator type etc.)
		cblock	0x20			;start of general purpose registers
			count
			count1
			counta
			countb
			COUNT_SEC
			LoX
			Bit_Cntr
			Timer_H
			Flags
			Flags2
			tmp1
			tmp2
			tmp3
			NumL
			NumH
			AARGB0
			AARGB1
			AARGB2
			AARGB3
			BARGB0
			BARGB1
			LOOPCOUNT
			REMB0
			REMB1
			TenK
			Thou
			Hund
			Tens
			Ones
			templcd
			templcd2
			Acc1L			;16 bit maths register 1
			Acc1H
			Point			;position of decimal point
;FREQUENCY VARIABLES
			FreqL
			FreqH
			TIMER1_LOW
			TIMER1_HIGH
			w_temp 				; To save off current W register contents
			status_temp
			freq_over
		endc
LCD_PORT	Equ	PORTD
LCD_TRIS	Equ	TRISD
LCD_RS		Equ	0x05			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
		ORG	0x0000
		NOP
		BCF	PCLATH,	3
		BCF	PCLATH,	4
		GOTO	start
;>>>>>>>>>>>>>>>>>>>>>>>>>>>>>frequency call>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
		ORG	0x0004
		MOVWF 	w_temp 		; save off current W register contents
		MOVF 	STATUS,w 		; move status register into W register
		MOVWF 	status_temp 	; save off contents of STATUS register
		BTFSC	T1CON, TMR1ON
		goto	Stop_timer1
		CLRF	TMR1H
		CLRF	TMR1L
		BSF		T1CON, TMR1ON
		GOTO	END_ANS_INT
Stop_timer1
		BCF		T1CON, TMR1ON
		MOVF	TMR1H, W
		MOVWF	TIMER1_HIGH
		MOVF	TMR1L, W
		MOVWF	TIMER1_LOW
		BSF		freq_over, 0X00
		;BCF		INTCON, INTE
END_ANS_INT
		MOVF 	status_temp,w 	; retrieve copy of STATUS register
		MOVWF 	STATUS 		; restore pre-isr STATUS register contents
		SWAPF 	w_temp,f
		SWAPF 	w_temp,w 		; restore pre-isr W register contents
		BCF		INTCON, INTF
		retfie
start
		errorlevel	-302
		bsf	INTCON,INTE		; Enable external interrupt
		bsf	INTCON,GIE
Initialise	clrf	count
		clrf	PORTA
		clrf	PORTD
		clrf	PORTC
		clrf	Flags
		clrf	REMB0
		clrf	REMB1
		movlw	b'00110000'
		movwf	T1CON
SetPorts	bsf 	STATUS,		RP0	;select bank 1
		movlw	0x00			;make all LCD pins outputs
		movwf	LCD_TRIS
		movlw	B'00000001'			;make all pins outputs
		movwf	TRISB
		bsf     OPTION_REG, NOT_RBPU
		bcf 	STATUS,		RP0	;select bank 0
		call	LCD_Init		;setup LCD module
		call	LCD_CurOff		;turn cursor off
		call 	Delay5
Main
;>>>>>>>>>>>>>>>>>>>>>>> READING VALUES FROM EXT. INT. FOR FREQUENCY >>>>>>>>>>>>>>>>>>>>>>
		movlw	b'00110000'
		movwf	T1CON
		BCF	freq_over, 0X00
CHECK_INT
		BTFSS	freq_over, 0X00
		GOTO	CHECK_INT
		BCF	INTCON,INTE
		BCF	freq_over, 0X00
		CALL	CALCULATE_FREQ
;>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> DISPLAY FREQ >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
		movlw	0xC0			;move to 1st row, first column
		call	LCD_Cmd
		movf	FreqH,w
		movwf	NumH
		movf	FreqL,w
		movwf	NumL
		call	LCD_Decimal		;and display on LCD (in decimal)
		movlw	' '
		call	LCD_Char		;display a space
		nop
		nop
		CALL	Delay5sec
		goto	Main			;loop for ever
;>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> CALCULATE_FREQ >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
CALCULATE_FREQ
		movlw	0x5F
		movwf	AARGB0
		movlw	0x5E
		movwf	AARGB1
		movlw	0x10
		movwf	AARGB2
		movf	TIMER1_HIGH,W
		movwf	BARGB0
		movf	TIMER1_LOW,W
		movwf	BARGB1
		call	FXD2416U		;DIVIDE 6250000/TIMER VALUE TO GET FREQUENCY WITH .1 RESOLUTION
		movf	AARGB1,w
		movwf	FreqH
		movf	AARGB2,w
		movwf	FreqL
		RETLW	0X00
;LCD ROUTINES.........
;DIVIDE ROUTINES.......
		end
First of all, there are safer and more accurate ways to measuring the time duration between edges than using the external interrupt. Using the capture module is an example.
Anyway, my guess is that although you have disabled external interrupts while calculating and displaying the frequency, the clock continues to be applied to the external interrupt pin. While the PIC is busy displaying the calculated result, the "INTCON, INTF" flag will be set but this will not cause an interrupt because it is masked.
After the 5 second delay, the moment you set "INTCON, INTE", with the "INTCON, INTF" flag already set, an interrupt is immediately fired even if the edge occured much earlier. The second clock edge will be encountered soon after that and the frequency read will be much higher.
The ff. code should correct this problem.
Main
      movlw   b'00110000'
      movwf   T1CON
      BCF   freq_over, 0X00
      BCF      INTCON, INTF ; **** Clear this first *****
CHECK_INT
      GOTO   CHECK_INT
      BCF   INTCON,INTE
      BCF   freq_over, 0X00
      CALL   CALCULATE_FREQ
hi thanks motion, your solution worked out very well.
i wanted to ask u abt the capture mode. wht is it actually m new to pic so i m not familiar with it. i just read in the datasheet abt it. but cant understand how to use it for frequency meter. can u please explain me abt it or give me a small example based on it.
thanks once again
thanks once again
Before I would get into the capture mode, I would like to mention the problems I see with using the external interrupt. The interrupt service time could severely limit the maximum frequency you can measure, maybe only up to 50-80Khz with increasing inaccuracy as frequency goes up. You didn't mention the frequency range you are trying to measure but since you are getting the reciprocal of the time interval, then I assume it is between 60Hz to 50Khz, not a very big range. You might do better if you simply count the number of pulses over a 1-5 second interval for example.
Why not consult the MicroChip application note for a frequency counter?. It's auto-ranging and goes from low audio to 50MHz, there's also a later update from Weeder Technologies that uses a more modern chip and an LCD disply module.
