external interrupt address
neelam29
if an timer overflow generates interrupt , the controller goes to location
ORG 0x04
so,when an external interrupt is generated where will the controller jump to ,i mean which address
org......?
and if it is same 0x04 ,then how will microcontroler differentiate between the two interrupts?
m using pic16f628a and pic16f877a
thanks
the pic will go to ORG 0x04 in any interrupt. Then you just check different interrupt flags to find out which interrupt occurred.
thanks for replying could u please tell me one more thing ...how to complement a bit in pic.cause comf instruction is used to comple ment the whole register......which instruction is used to complement only a bit ...
check this link: **broken link removed**
You can use the XOR instruction to complement a bit.
To complement bit 5 you would do,
         movlw   b'00100000'
         xorwf   Location,F
