Eusart
rahul_37
will any 1 help me in writing c code for Eusart communication with pc using hyper link my code is dis but its not working like i want to display what i typed in my pc keyboard on 16*2 LCD pleas help me
Counter On Each Interrupt
Interrupt Pin Assign to RB0
Data Lines aer connected to port D D0 - D7
E = RE2
RS = RE0
RW = RE1
CONTROLLER USED PIC16F887
#include <pic.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
__CONFIG (FOSC_INTRC_NOCLKOUT & WDTE_OFF & PWRTE_ON & MCLRE_ON & CP_ON & BOREN_ON & IESO_OFF & FCMEN_OFF & DEBUG_OFF);
#define PORTBIT(adr, bit) ((unsigned)(&adr)*8+(bit))
static bit RW @ PORTBIT(PORTE, 1);
static bit RS @ PORTBIT(PORTE, 0);
static bit ENA @ PORTBIT(PORTE, 2);
/***InitiallizeAll***/
void LCDDelay(unsigned int Delay);
void LCD_Display(void);
void InitialiseAll(void);
void clear_display(void);
void LCD_Initialliz(void);
void Nibble_seperat(void);
void debounce(void);
unsigned char Message1[17];
unsigned char Message2[17];
//void InitialiseAll(void);
unsigned char delaycount;
unsigned int i,J,K;
unsigned int Flag_1;
unsigned int DelayCount;
unsigned int num;
unsigned int temp;
unsigned int temp1;
unsigned int count;
unsigned int Int_Flag;
unsigned int a;
unsigned int Adc_Value;
unsigned int value;
unsigned int value1;
unsigned int b;
float t;
union abc
int count;
int Byte[2];
union abc ADC;
void main()
InitialiseAll();
LCD_Initialliz();
strcpy(Message1,"Degre Centigrade");
strcpy(Message2," C ");
LCD_Display();
for(i=0;i<65500;i++);
while(1)
if(RCIF)
temp1 = RCREG;
Nibble_seperat();
LCD_Display();
void InitialiseAll()
OSCCON=0B11100001;
// SPBRG = 25; // 9600 baud @ 8MHz
// TXSTA = 0x24; // setup USART transmit
// RCSTA = 0x90; // setup USART receive
PORTC = 0; // Clear PORTC
TRISC = 0X80; //
// TRISC = 0b11110010;
SPBRG=25;
RCSTA=0b10010000;
TXSTA=0b00100100;
T1CON=0X00;
CCP1CON=0X00;
CCP2CON=0X00;
OPTION_REG = 0b10000111; //1:256
ANSEL = 0b00000000;
ANSELH = 0b00000000;
ADCON0 = 0b00000000;
ADCON1 = 0b00000000;
CM1CON0 = 0b00000000;
CM2CON0 = 0b00000000;
INTCON = 0b11010000;
OSCCON = 0b01110001;
PORTA = 0;
TRISA = 0X00;
PORTB = 0;
TRISB = 0b00000000;
PORTD=0;
TRISD=0X00;
PORTE=0;
TRISE=0X00;
WPUB=0B11111111;
GIE=1;
PEIE=1;
void Nibble_seperat()
for(i=0;i<=2;i++)
temp=temp1%10;
temp1=temp1/10;
temp=temp+48;
Message2[9-i]=temp;
void LCD_Initialliz()
LCDDelay(80000);
PORTD=0X3B; // FUNCTION SET 8 BIT 2 LINES 5*8 DISPLAY
LCDDelay(100);
LCDDelay(100);
LCDDelay(200);
PORTD=0X0C; // DISPLAY ON
LCDDelay(100);
PORTD=0X01; // CLEAR DISPLAY
LCDDelay(2740);
PORTD=0X05; // ENTRY MODE
LCDDelay(100);
PORTD=0X03; // RETURN HOME
LCDDelay(100);
PORTD=0X17; // DISPLAY SHIFT.
LCDDelay(100);
ENA = 1;
for(i=0;i<Delay;i++);
ENA = 0;
void LCD_Display()
PORTD = 0x80; // Send Command to select Line 1
LCDDelay(500);
for(i=0;i<50;i++);
for(DelayCount=0;DelayCount<16;DelayCount++) // Display Line 1
RS = 1;
PORTD = Message1[DelayCount];
LCDDelay(500);
RS = 0;
PORTD = 0xC0; // Send Command to select Line 2
LCDDelay(500);
for(i=0;i<50;i++);
for(DelayCount=0;DelayCount<16;DelayCount++) // Display Line 2
RS = 1;
PORTD = Message2[DelayCount];
LCDDelay(500);
RS = 0;
