edofbrighton
Can anyone tell me why the transmit Ethernet lines have 50 ohm termination resistors fitted at the source? My understanding is that you only need to have a termination at the end of a signal line. There should be a 50 source impedance, a 50 ohm characteristic impedance of the transmission line, and a 50 ohm termination resistance. Is it because Ethernet is a differential pair you need a bi-directional 100 ohm differential termination at both ends (2x 50 ohms).
Thanks in advance
Thanks in advance
