Ethernet for PICs using ENC28J60
Yobortsa
Hi all,
I am dabbling with Microchip's ENC28J60 10baseT ethernet chip and a PIC12F675 at the moment, but thinking this is too much of a challenge for a newbie and perhaps I should use the Microchip TCP/IP stack first (which was designed for at least PIC18 MCUs) rather than writing my own SPI bit-bang routines for a 12F675 and working at packet level.
Which of the PIC18 MCUs is a good starting point for the ENC28J60?
Obviously it needs an SPI interface and I'm not concerned with any other specific I/O functionality at this point nor do I have any requirement for significant RAM or program memory.
All I have used so far is a PIC12F675, so the simpler the better!
Thanks,
David
12F675 code for SPI if anybody is interested
Here is the 12F675 SPI bit-bang code I've written so far if anybody is interested, but I haven't even been able to figure out if it's working or not. I'm not confident the timing is 100% but it looks ok on a scope (I think!).
#include <p12F675.inc>
;     __CONFIG (_INTRC_OSC_NOCLKOUT & _WDT_OFF &_BODEN_OFF &_CP_OFF &_CPD_OFF & _MCLRE_OFF)
     __CONFIG (_INTRC_OSC_NOCLKOUT & _WDT_OFF &_BODEN_OFF &_CP_OFF &_CPD_OFF)
; RAM allocation
; Register locations 20h-5Fh are General Purpose registers,
; implemented as static RAM and are mapped across both banks.
COUNT1		equ	020h		;First counter for our delay loops
COUNT2		equ	021h		;Second counter for our delay loops
spi_in1		equ	022h
spi_in2		equ	023h
spi_in3		equ	024h
spi_out1	equ	025h
spi_out2	equ	026h
spi_out3	equ	027h
spi_status	equ	028h
spi_bit		equ	029h		; Bit number counter
spi_count	equ	02ah		; Number of bytes to read/write
spi_in		equ	02bh		; Points to spi in buffer
spi_out		equ	02ch		; Points to spi out buffer
; ENC28J60 Instructions and Registers
RCR		equ	000h
RBM		equ	020h
WCR		equ	040h
WBM		equ	060h
BFS		equ	080h
BFC		equ	0a0h
SRC		equ	0ffh
; Bank 0
ERDPTL		EQU	00h
ERDPTH		EQU	01h
EWRPTL		EQU	02h
EWRPTH		EQU	03h
ETXSTL		EQU	04h
ETXSTH		EQU	05h
ETXNDL		EQU	06h
ETXNDH		EQU	07h
ERXSTL		EQU	08h
ERXSTH		EQU	09h
ERXNDL		EQU	0ah
ERXNDH		EQU	0bh
ERXRDPTL	EQU	0ch
ERXRDPTH	EQU	0dh
ERXWRPTL	EQU	0eh
ERXWRPTH	EQU	0fh
EDMASTL		EQU	10h
EDMASTH		EQU	11h
EDMANDL		EQU	12h
EDMANDH		EQU	13h
EDMADSTL	EQU	14h
EDMADSTH	EQU	15h
EDMACSL		EQU	16h
EDMACSH		EQU	17h
; Bank1
EHT0		EQU	00h
EHT1		EQU	01h
EHT2		EQU	02h
EHT3		EQU	03h
EHT4		EQU	04h
EHT5		EQU	05h
EHT6		EQU	06h
EHT7		EQU	07h
EPMM0		EQU	08h
EPMM1		EQU	09h
EPMM2		EQU	0ah
EPMM3		EQU	0bh
EPMM4		EQU	0ch
EPMM5		EQU	0dh
EPMM6		EQU	0eh
EPMM7		EQU	0fh
EPMCSL		EQU	10h
EPMCSH		EQU	11h
EPMOL		EQU	14h
EPMOH		EQU	15h
ERXFCON		EQU	18h
EPKTCNT		EQU	19h
; Bank2
MACON1		EQU	00h
MACON3		EQU	02h
MACON4		EQU	03h
MABBIPG		EQU	04h
MAIPGL		EQU	06h
MAIPGH		EQU	07h
MACLCON1	EQU	08h
MACLCON2	EQU	09h
MAMXFLL		EQU	0ah
MAMXFLH		EQU	0bh
MICMD		EQU	12h
MIREGADR	EQU	14h
MIWRL		EQU	16h
MIWRH		EQU	17h
MIRDL		EQU	18h
MIRDH		EQU	19h
; Bank3
MAADR5		EQU	00h
MAADR6		EQU	01h
MAADR3		EQU	02h
MAADR4		EQU	03h
MAADR1		EQU	04h
MAADR2		EQU	05h
EBSTSD		EQU	06h
EBSTCON		EQU	07h
EBSTCSL		EQU	08h
EBSTCSH		EQU	09h
MISTAT		EQU	0ah
EREVID		EQU	12h
ECOCON		EQU	15h
EFLOCON		EQU	17h
EPAUSL		EQU	18h
EPAUSH		EQU	19h
; Registers common to all banks...
EIE		EQU	1bh
EIR		EQU	1ch
ESTAT		EQU	1dh
ECON2		EQU	1eh
ECON1		EQU	1fh
; Physical registers
PHCON1		EQU	00h
PHSTAT1		EQU	01h
PHID1		EQU	02h
PHID2		EQU	03h
PHCON2		EQU	10h
PHSTAT2		EQU	11h
PHIE		EQU	12h
PHIR		EQU	13h
PHLCON		EQU	14h
	org 0h
;	goto Init
;	org 04h
;	retfie
; Init inputs and outputs by setting TRISIO port
; TRISIO bit = 1 Input
; TRISIO bit = 0 Output
; Can either set my moving 8 bit value to W register then moving W to F or by using BSF (set bit 1) or BCF (set bit 0):
;   bsf     STATUS,5	; Switch to Bank 1
;	movlw   b'00110101' ; Set the Port A pins
;	movwf   TRISIO      ;
;   bcf     STATUS,5	; Switch back to Bank 0
Init
;	org 10h
	movlw	b'00100000' 	; Set I/O 1 output (for SCK - clock)
				; Set I/O 2 output (for CS - Slave Select)
	movwf	TRISIO		; Set I/O 4 output (for SO - to SI on ENC28J60)
				; Set I/O 5 input (for SI - to SO on ENC28J60)
	movlw	b'00000100' 	; Set cs high, all other outputs low
	movwf	GPIO
; Setting an output high or low
; If it's only one output you want to update, use BSF (to set high) or BCF (to set low):
;	bsf		GPIO,0		; Set GP IO 0 high
;	Call Delay
;	bcf		GPIO,2		; Set GP IO 2 low
;	bsf	GPIO,0
;	call DelayLong
;	bcf	GPIO,0
	call DelayLong
doagain
	movlw	2
	movwf	spi_count	; Set the number of bytes to send/receive
	movlw	RCR | ERXFCON
	movwf	spi_out1
	call spi
	goto doagain
	movlw	2
	movlw	WCR | ECON1
	movwf	spi_out1	; Write ECON1
	movlw	2
	movwf	spi_out2	; Switch to bank 2
	call spi
	movlw	2
	movlw	WCR | MIREGADR
	movlw	PHLCON
	movwf	spi_out2
	call	spi
	movlw	2
	movwf	spi_count
	movlw	WCR | MIWRL
	movlw	b'10000010'
	call	spi
	movlw	2
	movwf	spi_count
	movlw	WCR | MIWRH
	movlw	b'00111000'
	call	spi
	goto doagain
; SPI subroutine
; Call with:
;  spi_count set to the number of bytes to write/read
;  spi_in set to the first register address of the inbound buffer
;  spi_out set to the first register address of the outbound buffer
spi
	movlw	spi_in1
	movwf	spi_in		; Set the start of the inbound buffer
	movlw	spi_out1
	movwf	spi_out		; Set the start of the outbound buffer
	movlw	8		; Set bit counter
	movwf	spi_bit		;   to 8 bits
	bcf	GPIO,2		; Set CS line low
spi_looplong
	nop
	nop
	nop
	nop
	nop
	nop
	nop
spi_loop
	bcf	GPIO,1		; **** Set clock line low ****
	movf	spi_out,W	; Point to next spi_out byte
	movwf	FSR		;   with File Select Register
	rlf	INDF,F		; Roll next data bit into Carry flag
	btfss	STATUS,C	; Is it high? If yes, skip...
	goto BitLow
	bsf	GPIO,4		; Set SO line high
	goto spi_donebit	; We have done the bit, continue on...
BitLow
	bcf	GPIO,4		; Set SO line low
	nop			; Wait an extra cycle if BitLow to match high alternative
spi_donebit
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	nop
	bcf	STATUS,C	; Clear the Carry flag
	bsf	GPIO,1		; **** Set clock line high ****
	btfsc	GPIO,5		; Read bit from SI line, skip if clear (0)
	bsf	STATUS,C	; Set the Carry flag if bit not clear (1)
	movf	spi_in,W	; Point to next spi_in byte
	rlf	INDF,F		; Roll the incoming bit into the buffer
	nop			; Wait an extra cycle to match other side of clock
	decfsz	spi_bit,F	; Decrement bit counter, skip if zero
	goto spi_looplong	; Go do next bit...
	decfsz	spi_count,F	; Decrement our byte counter, skip if zero
	goto spi_nextbyte	; Go do next byte, otherwise...
	nop			; Wait 210ns (each instruction is 1us or 1000ns)
	bsf	GPIO,2		; Set CS high
	return			; Return to program
spi_nextbyte
	movlw	8		; Reset bit counter
	movwf	spi_bit		;   for next 8 bits
	incf	spi_out,F	; Point to next byte in outbound buffer
	incf	spi_in,F	; Point to next byte in inbound buffer
	goto spi_loop		; Go do next byte...
; Delay subroutine
DelayLong
	call Delay
	call Delay
	call Delay
	call Delay
	call Delay
	call Delay
	call Delay
	call Delay
	call Delay
	return
Delay
Loop1
	decfsz	COUNT1,1    ; This second loop keeps the LED
    goto Loop1          ; turned off long enough for us to
    decfsz	COUNT2,1    ; see it turned off
    goto Loop1          ;
	return
	end
Hey im very interested in this project. Can someone post all the parts needed to set up a ethernet board..
I know i need the:
ENC28J60
and was looking at the schematics for the eval board. I need also:
25mhz crystal
50 ohm resistors
180 ohm resistors
2.7k resistors
10uf caps
0.1uf caps
33pf caps
I see a L1 but i think its a ferret beed
Ethernet Jack
they have a 256K SPI™ Bus Serial EEPROM but not sure if its needed 100%
and a PIC of course but anything else? Or something i can change or something?
You need the Ethernet transformer or a RJ45 jack with it built in. You don''t need the extra eeprom unless you want to store more web pages or data than the flash on the PIC will hold. It is not a hard project if you use MicroChip's stack. Here is a picture of a 18F4620 interfaced to the ENC28J60 (minus the RJ45 jack) which shows how simple the hardware is:
That's where I got the Valor FL1012 from. :D
heh if thats the case i have a bunch of old motherboards. im sure they have the transformer stuff built into the jack. It seems like a save :D
Thanks for the tip. You think it would be hard to implement a SPI eeprom or infact a SD card using SPI just like a eeprom ? Does the stack have a fat32 type structure or is it custom?
I watched so many videos its not funny. I love the web vending machine one. I seen all 3 and fell in love. i would love to make a ethernet board so i can monitor stuff and host or send the data to myself.
1 question... does the ethernet stack have a server type code built in? So when i connect it, it will serve the info auto? Or does one need it to a PC ?
The Microchip stack, that I used, had the code for I2C eeprom already. You'd have to write your own if you wanted SPI.
The stack had it's own file format called MPFS. I seem to remember that Microchip also provided a utility to convert files to MPFS format.
Yes. The one I played with was the HTTP server. It served up a webpage where you could turn on a LED with a mouse click and read values from the ADC with your web browser. You did need a terminal program to setup DCHP or static IP's via the serial port if you didn't want to modify the code and hard code those options in. Pretty neat little application. There were also FTP & SNMP modules available.
Thats awesome. I would make a little handheld device to program them This way no PC is needed and its not hard coded.
This sounds awesome. Is it still like:
microchip.com/tcpip ?
What you are looking for is called a MagJack. Your DipMicro site has cheap ethernet connectors with built in magnetics. OEM ethernet cards and Motherboards and such almost always have the magnetics seperate from the jack.
Check out the hackaday articles:
How-To: Web server on a business card (Part 1) - Hack a Day
How-To: Web server on a business card (Part 2) - Hack a Day
Personally I use a Wiznet W5100 for an 8bit uC solution. It's real easy, with the TCP stack right on chip. You can have simple servers running with just a state machine on the uC. Unfortunately they seemed to have jacked up the price of the w5100 to $5 each. Also it is a hard chip to etch for/mount. It has 0.4mm lead spacing, which means board houses with 8mil spacing requirements wont work with it. 0.4mm is very odd spacing.
Also the higher series Stellaris Cortex-M3 uC's have a MAC/PHY built right into the chip and are ready to go. You already have a JTAG programmer and Crossworks. You may not want to try that out right at first, but keep it in mind. I'm definitely going to be trying them out sometime when I have the time.
the motherboards i have dont have no seperate magnets. all is single. But i will def... get from DipMicro.
After i learn this im moving over to GSM. Ill buy a cheap sim card (prepaid) and test it out. I guess i would need 2 sim cards and 2 GSM modules but heh it will be fun.
Do you think i should contact GSM company like tmobile and ask if there is a plan i can put the chip on so i just have data? and thus save money
Jason
Have a look at the attached.
Rupert
  • WIZ812MJ Datasheet_V_1.1.pdf
It works for me. It's just the datasheet for the Wiznet W5100 premade module.
That's what I originally tested with before I made up a board.
@DirtyLude
I am just playing with one at the moment - did you manage to get DHCP working on it?
Rupert
I haven't implemented DHCP on it. I just assigned a static IP, since it's connecting to my home network. I guess I should put in DHCP sometime, but it's not a priority for me. I'm actually working with the W5300 now. Pretty much the same thing in terms of interface, though.
I'm currently working on a simple RF mesh network that I'd like to integrate into the HTTP server and be able to control RF nodes and read sensor data over the web.
its my pc :( but its wierd only that pdf... i will try to convert all to jpgs and read it. If not ill try my virtual box pc and see if i can peek in
Edit:
Finally got it to work ok. I had to split it with photoshop into 14 different pages then merge it back heh nice device
