error in code assembler
mpardinho
i use this code but then i compile occurs some errors
help me with erros in lines please
i use picsimulator ide / assembler to test the code above.
ERRORS ARE IN RED
    DataPin equ 0x06                  ;PIC Pin
    ClockPin equ 0x07                 ;PIC Pin
    Char equ 0x35                      ;buffer
    BitCounter equ 0x36              ;number of bits to read
GetScanCode
    bsf STATUS, RP0                   ;select bank 1
    sf TRISB, DataPin                  ;set pins as input
    bsf TRISB, ClockPin
    bcf OPTION_REG, NOT_RBPU    ;pull-ups are enabled
    bcf STATUS, RP0                   ;select bank 0
    call ClockWait                       ;wait for Pull up to take effect and                          keyboard to pull clock low
;--- Read Data Bits ----
ReadKey
    clrf Char                           ;
    movlw .8                          ;bits to read
    movwf BitCounter
ReadChar
    rrf Char                           [COLOR="Red"]Error: Invalid argument[/COLOR]
    bcf Char, 7                       ;default value is 0
    call ClockWait                    ;wait for clock to go high then low
    btfss PORTB, DataPin              ;read Data
    goto Next                         [COLOR="Red"]Invalid argument of the instruction[/COLOR]
    bsf Char, 7                       ;Data is High
    Next decfsz BitCounter            [COLOR="Red"]Unrecognized instruction[/COLOR]
    goto ReadChar                     ;read next Data Bit
call ClockWait                    ;Parity Bit
call ClockWait                    ;Stop Bit
;Pull Clock Line Low (keyboard will buffer any further keystrokes)
    bcf TRISB, ClockPin               ;set clock line as output
    bcf PORTB, ClockPin               ;set clock line low
    movf Char, W
return
;----wait for clock to go high----
ClockWait
    btfss PORTB, ClockPin
    goto ClockWait
;----wait for clock to go low----
ClockWait2
    btfsc PORTB, ClockPin
    goto ClockWait2
I think you just need to indent your code so it looks like this.
GetScanCode
	bsf TRISB, DataPin                ;set pins as input
	bsf TRISB, ClockPin
HTH
column 0 for 'labels' only, it needs spaces or tabs at the start of all non 'label' lines.
Try changing it to
ReadChar
    rrf Char,1                          ;Error: Invalid argument
    goto Next                         ;Invalid argument of the instruction
Next decfsz BitCounter            ;Unrecognized instruction
That should now assemble.
However, as Nigel says, the microchip assembler is better. Download **broken link removed** free from microchip.
