Error - could not find definition of symbol 'SPBRG'
how to send transter some byte from hyperterminal to PIC
as a part of the interrupt test i need to send some bytes of data by using the serial port. the data should resend me back. can i use Hyperterminal? if yes how?
It looks like UARTInC.h is a copy of p18f4620.h.
Why did you do that?
after doing the successful 'built' i tried to 'program' the PIC. that also programmed successfully. but whenever i connect the hyperterminal it shows previous program output as i did test program on the PIC as a zigbee node. it means previous program is not erased. how can i erase the flash?
Are you using MPLAB? Which programmer?
If you are using MPLAB with either ICD2 or PICkit2 as a programmer there are erase and blank check buttons/icons.
The PICkit2 interface has them too.
sorry i have copied the wrong one. here it is
#ifndef _UARTIntC_H
#define	_UARTIntC_H
#include "UARTIntC.def"
/* Constants found in .def file are given readable names*/
#define TX_BUFFER_SIZE UARTINTC_TX_BUFFER_SIZE
#define RX_BUFFER_SIZE UARTINTC_RX_BUFFER_SIZE
#ifdef UARTINTC_TXON
  #define TXON 1
#elif UARTINTC_TXOFF
  #define TXON 0
#endif
#ifdef UARTINTC_RXON
  #define RXON 1
#elif UARTINTC_RXOFF
  #define RXON 0
#endif
#define TXON_AND_RXON ((TXON) & (RXON))
#define	TXOFF_AND_RXON ((!(TXON)) & (RXON))
// User can change the following values and accordingly
// the ISR location in the main application.
//   Can they be MPAM module parameters?
#define BRGH_VAL 1
#define	TX_PRIORITY_ON	0
#define	RX_PRIORITY_ON	0
// More error check to be done and the following
// code can be modified.
// If SPBRG is out of range, it won't let the
// main application be compiled and linked.
#define SPBRG_V1  (UART_CLOCK_FREQ / UARTINTC_BAUDRATE)
#define SPBRG_V2  SPBRG_V1/16
#define SPBRG_VAL  (SPBRG_V2 - 1)
# if (SPBRG_VAL > 255)
  #error Calculated SPBRG value is out of range
#elif (SPBRG_VAL < 10)
#endif
struct status
	unsigned UARTIntTxBufferFull  :1;
	unsigned UARTIntTxBufferEmpty :1;
	unsigned UARTIntRxBufferFull  :1;
	unsigned UARTIntRxBufferEmpty :1;
	unsigned UARTIntRxOverFlow :1;
	unsigned UARTIntRxError:1;
extern struct status vUARTIntStatus;
//  variables representing status of transmission buffer and
//  transmission buffer it self are declared below
#if TXON
extern unsigned char vUARTIntTxBuffer[TX_BUFFER_SIZE];
extern unsigned char vUARTIntTxBufDataCnt;
extern unsigned char vUARTIntTxBufWrPtr;
extern unsigned char vUARTIntTxBufRdPtr;
#endif
// variables referring the status of receive buffer.
#if	RXON
extern unsigned char vUARTIntRxBuffer[RX_BUFFER_SIZE];
extern unsigned char vUARTIntRxBufDataCnt;
extern unsigned char vUARTIntRxBufWrPtr;
extern unsigned char vUARTIntRxBufRdPtr;
#endif
//  functions offered by this module
#if	RXON
// function returns a character from receive buffer
unsigned char UARTIntGetChar(unsigned char*);
// function returns the number of characters in receive buffer
unsigned char UARTIntGetRxBufferDataSize(void);
#endif
#if	TXON
// function to put a character in Transmit buffer
unsigned char UARTIntPutChar(unsigned char);
// function returns size of the empty section of Transmit buffer
unsigned char UARTIntGetTxBufferEmptySpace(void);
#endif
// Initialisation of the module
void UARTIntInit(void);
// Interrupt service routine supplied by the module.This need to be
// called from ISR of the main program.
void UARTIntISR(void);
// Other useful macros
#define mDisableUARTTxInt()				PIE1bits.TXIE = 0
#define mEnableUARTTxInt()				PIE1bits.TXIE = 1
#define mDisableUARTRxInt() 			PIE1bits.RCIE = 0
#define mEnableUARTRxInt()  			PIE1bits.RCIE = 1
#define mSetUARTRxIntHighPrior() \
										RCONbits.IPEN = 1;\
										IPR1bits.RCIP = 1
#define mSetUARTRxIntLowPrior() 		IPR1bits.RCIP = 0
#define mSetUARTTxIntHighPrior()\
										RCONbits.IPEN = 1;\
										IPR1bits.TXIP = 1
#define mSetUARTTxIntLowPrior()			IPR1bits.TXIP = 0
#define mSetUART_BRGHHigh()				TXSTAbits.BRGH = 1
#define mSetUART_BRGHLow()				TXSTAbits.BRGH = 0
#define mSetUART_SPBRG(iBRGValue)\
										RCSTAbits.SPEN = 0;\
										SPBRG = iBRGValue;\
										RCSTAbits.SPEN = 1
#define mSetUARTBaud(iBaudRate)\
		do{\
			#define SPBRG_V11  (UART_CLOCK_FREQ / UARTINTC_BAUDRATE)\
			#define SPBRG_V21  SPBRG_V11/16\
			#define SPBRG_VAL  (SPBRG_V21 - 1)\
			#if (SPBRG_VAL > 255)\
			  #error Calculated SPBRG value is out of range\
			#elif (SPBRG_VAL < 10)\
			#endif\
			SPBRG = iBaudRate;\
			RCSTAbits.SPEN = 1;\
		}while(false)
Yes, i erase the PIC.
please have look on the code i used as main.c file.
How can send data fron pc to mic-Con?
#include "UARTIntC.h"
#include "delays.h"
#include <p18f4620.h>
void low_isr(void);
// serial interrupt taken as low priority interrupt
#pragma code uart_int_service = 0x08
void uart_int_service(void)
	_asm	goto low_isr	_endasm
#pragma code
#pragma	interruptlow low_isr save=section(".tmpdata")
void low_isr(void)
	// call of library module function, MUST
	UARTIntISR();
void main(void)
	// Test data array
	unsigned char cArray[10]
	   = { 'A','B', 'C', 'D', 'E', 'F', 'G','H','I' , 'J'};
	// temporary local array
	unsigned char writtenArray[10];
	// local variables for all test cases and their initialisation
	unsigned char chData;
	unsigned char *pReadArray;
	unsigned char *pWriteArray;
	unsigned char j = 0;
	unsigned char i  = 0;
	unsigned char l = 0;
	unsigned char k = 0;
	pReadArray = pWriteArray = writtenArray;
	// call of library module , MUST
	UARTIntInit();
//	TEST
// 	Chunk of data is sent from PC to micro. Data received at micro is
//	read in to temporary buffer. The data is sent back to PC. Here
//  reception and transmission is done independently.
	while(1)
		l = 0;
		l = UARTIntGetRxBufferDataSize();
		while(l > 0)
			if(UARTIntGetChar(pReadArray))
				l--; pReadArray++;
				if(pReadArray == (writtenArray + 10))
					pReadArray = writtenArray;
	if((pWriteArray < pReadArray) || ((pWriteArray - pReadArray) == 9 ))
			if(!vUARTIntStatus.UARTIntTxBufferFull)
				UARTIntPutChar(*pWriteArray);
	    		i--; pWriteArray++;
 			    if(pWriteArray == (writtenArray + 10))
SPBRG only appears to be used in a #define (in the .h) and shouldn't have thrown an error. Or, did I miss something?
It was used in UARTIntC.h.
He included UARTIntC.h prior to including p18f4620.h so SPBRG was undefined in UARTIntC.h . He needed to include p18f4620.h first.
I have run so do not have time to answer the new question.
You missed the point. SPBRG is only used in a #define and therefore is not evaluated in the .h file.
If I do,
#define crap nonsense
then it will compile fine unless I use crap.
As to the original error, I have no idea. I just don't understand this solution.
If I do,
I did and you are right. But we have yet to see UARTIntC.def which is included in UARTIntC.h. Could be that he uses SPBRG in it.
