equivalent ic of MBI 5169
aslamshaikh42
Hi everyone,
can anybody tell me which is the equivalent ic of MBI5169
this is is not available in many shops
so i require its replacement which will be available easily
thanku in advance.
you can try PCA9922. NXP.com
8-channel Constant Current Led Driver With Output Error Detection
thank u very much
but i hv made a pcb in which the package of mbi 5169 is simple sop-16 small outline & pca has a wide package so can you give another ic having the same package & pin config.
thank u
Bad luck. Usually I will buy Ic first then make a PCB.
My advice is that you need forget the MBI5169 ,make a new PCB.Don't waste your time
