Equipment for Hobbyists
I've used ATX supplies in a professional lab environment. One advantage is the other engineers are less likely to steal them.
LM317 is a linear regulator, so it's power dissipated limited, forget to put a heat sink on it and it goes up in smoke, not so good for a hobbyist that doesn't know it. The ATX power supply takes care of all the nasty details for you for a basic +5 +12 -12 supply.
No it won't, it's thermally protected so it will shut down rather than smoking.
I started from scratch two years ago. I recommend the Tektronix TDS scopes. 2 channel, digital. I have the 1002, bought on ebay for around 550USD. Although I use my DMM more, the scope is absolutely life-changing. Even does fourier transforms.
Dual Power supply: used HP 6205B on ebay for ~100USD.
I've just started with PICs. Bought a cheap 100USD laptop, Pickit 2 programmer and got FREE microcontroller samples from 'sample dot microchip dot com.' It's all free except for the programmer. Bye.
Wow $550 for a Tek digital is a good price. I am still just using a Tek 2236 analog which I picked up at a swap meet for $200.
Why did you have to buy a $100 laptop to program a PIC? Also, is PICkit2 better than Junebug? From what I have read Junebug has everything PICkit2 has and some.
Speaking of equipment for hobbyists... I am looking to purchase a very basic/cheap laser printer to create my own pcb's. Anyone know of any good laser printers that are cheap?
Why use your main and expensive PC to program PIC's? Better to lose a $100. laptop than your business end of computing.
Is a Tektronix TDS-220 Digital Oscilloscope a good buy at $600?
I would say yes if it works and is in good shape. Any extras like probes?
Why would you lose your computer? Is it possible to damage your computer when programming PICs!? If so, do the programming kits such as Junebug and PICkit2 come with some sort of "fuse" to prevent damage to your computer? If not, then I guess I will have to whip out my 9 year old Gateway desktop computer that has been accumulating dust in the corner of my room :)
I guess my point was, it is nicer to use an expendable PC for projects than your main use computer. I am sure the odds of frying a PC are slim, rather than just an interface card, but why chance it if not needed?
I would get an extra PC to open PDF files then, because Adobe software damages my PC more than any tools I use for micros. :D
Seriously, though, this is not a concern, so have no fear on this.
I would assume that the usb controller/module would fail and end any issues then and there. I can tell you that the AVRISPMKII (usb programmer) for AVRs has protections to guard against this, and even allows shorting and improper polarity wiring as included safeguards. If you do program, think about AVRs, only took me a week to master most of my AVR's peripherals and functions after having only a semester of a microprocessors class. (I went from using 68HC11s)
Henry, ATX supplies are short circuit protected. I've never tested the +3.3 volt lines on mine, but tested both the +12 -12 and +5 main lines. I've plugged an RS232 board accidentally inverted into my PC, so it's 24 volts, power supply 'clicks' and humms in shutdown but no damage to any circuits. I wouldn't rely on it for 'serious' current limiting, but for a hobbyist it's wonderful.
Was there a diode in series with the power supply? Then of course there isn't a problem, but if it's not...
An ATX-power supply can deliver what? like 20Amps at 5V or something, imagine 20Amps going through a little beginners circuit. Off course it is easy for testing and as long as you don't screw up big time, you'll be fine, but the moment you need a GOOD power supply, no ripple, no HF-junk, I think it's better to invest in a good power supply...
LM317's can take everything, as can 78xx, they are better protected than you could imagine, current limiting, thermal safety shutdown, maybe oscillation will get it to go sky high, but i never ran across that..
Henry... ATX power supplies are short circuit protected. Better yet they're DV/DT limited. You can't just slam a 20 amp load onto an ATX supply no matter what it's max current output is it'll shutdown asuming a short, current has to be ramped up. I'm a little surprised you're taking hits at ATX power supplies, they run almost every home computer in existence and the majority of PC failures have nothing to do with the power supply. I've also never heard of an ATX power supply bursting into flames unless tampered with to deliberately malfunction. The modifications to an ATX power supply for use as a hobby supply doesn't fundamentally alter any critical component of the supply.
I didn't say anything about the ATX bursting in flames, but the circuit on which you're working...
They are used in computers, because that is what they are made FOR, and imagine if you have a few HDD in your computer and they all fire up, imagine what kind of current goes through that? Yes they are short circuit protected, but that doesn't take away the fact that they can deliver HUGE currents.
ATX power supplies have proven their usability, in Computers, let them be there, they are designed for computers. I am not taking hits at the ATX concept, just the thought of a ATX power supply in a (for instance) breadbord circuit doesn't make me feel happy...
But if you want to use an ATX for something, I won't stop you, besides, NY is a bit out of the way for me to be doing with my bike :p
Dutch company I was working for had the problem with ATX PSU bursting in flames .. over 30 times .. We had ~200 computers .. in timespan of 6 months over 30 of them "exploded" .. "bursted in flames" .. etc.. one managed to output 10-15cm flame out the fan while I was holding it !!!
So, "good" PSU from "good" manufacturer will have "good" protection, but those 3-10$ PSU's can do many "interesting" things ... like burst into flames, shoot capacitors trough fan etc..
One "interesting" thing is that from those ~30 PSU "explosions" ~15 times no damage was done to the computer except that PSU had to be replaced, in other ~15 cases EVERYTHING (including keyboard and mouse) except CRT monitor was fried.
I personally use ATX PSU as hobby power supply as I have many of them and that is cheapest way to have ... but ... they can go kaboooom, I know, I saw it too many times
Laptop for PICs, and cheap digital Tektronix scopes.
The (very good) free development environment that Microchip supplies (MPLAB) only works under Windows. I owned a Mac. So, I bought a 100 dollar laptop, windows 2000, 400MHz. That's the only reason.
Back on topic: I don't know about other programmers etc. I just wanted something that worked seamlessly. Let me put it this way; I'd rather pay an extra few dollars, or do the boring/simplest thing, than spend an afternoon fiddling around with software/hardware compatibility issues. Everything I use that's PIC-related is from Microchip, and apart from one add thing (why is 16F54 programmable in Pickit 2 application but not MLAB?) everyhting has run absolutely seamlessly. For books I recommend (as do many others) Morton's introductory book, and of course printing out a couple of PIC datasheets. I'm enjoying PICs immensely.
After studying the Tektronix website, it became clear that there were only a couple of digital Tek scopes I could afford. If you ebay it, google 'TDS 220 recall' or whichever you find, because there was a recall for some of them. 500-600 bucks for any of the B&W Tektronix digital scopes is a typical price. I've seen TDS 1002 for same price as 220, so you might keep an eye out for 1002 models. Slightly better. In the long run +/- 50 bucks is not to be worried about. Worse things happen (to oscilloscopes) at sea.
My last mention of ATX. Henry, I've on multiple occasions dead shorted the +12 volt line to a solid ground with heavy wire, nothing but a tiny arc before the supply shuts down. I've used it on my breadboards since I've owned bread boards, many dead shorts, no part failures of any kind, and as I've said, I hooked up my STK500s power leads wrong and it was running off of a -12 volt supply when I hooked up the RS232 to my PC (+12) and the power supply shut down, I did this over a dozen times before I realized what was wrong. STK500 and PC were both fine and no glitches aside from power loss. They are as intrinsically safe as you can get in a power supply. Many professional power supplies would not shut down under the same circumstances as an ATX supply would, in fact I hear this is a problem with some people using them for high power PWM as the DV/DT the PWM places on the line shuts the power supply down, they have to use load resistors before large electrolytics to buffer the power line enough to let them draw the high pulse currents.
