Embedded C programming
Angy
If anyone has easy to understand source of info on embedded c,Please post it on this thread.
Thanks a lot!
Can anyone tell me what this means in a c program?
unsigned int *ADCmemory=(unsigned int *)0x3200
ADCmemory will hold an address pointing to an unsigned integer and the address of that unsigned integer is 0x3200.
Dale
Hello,
can someone tell me what this ' -> ' means in C?
Atimer = brushfan -> statefantimeout;
Thanks.
I do not care for C++ but ...
the -> operator lets you get from an object pointer to a real object or a an attribute of the real object.
Look at the definitions for Atimer and brushfan and you should find statefantimeout.
Anyone who can do better please speak up.
3v0
Pretty much right.
I might hate C++ more than you 3v0... Especially in embedded apps. Statefantimeout is just a variable that is the property of brushfan.
It's exactly the same as;
Atimer = statefantimeout;
But longer, uglier, more typing, more to go wrong and probably slower and worse to compile to assembler for the micro to use.
Down with C++! C-- rules. ;)
I should clarify
Object oriented programming can be a very good thing in a large application. The kind that will not fit on most micros.
C++ is a good example of how not to implement a OO language.
Given a choice I will use C#. Do not carp about it being MS as there is good support for the open source version mono. You can even use visual studio on vista to debug a C# program running under linux.
3v0
The arrow operator is used in C. It's how you dereference a pointer to a struct or union and access its members.
is the more readable way of writing
Atimer = (*brushfan).statefantimeout.
