Electronic speed controller
teli
Hi
Anobody got a "easy" R/C speed controller design ?
I'm building a Tank that has two RS-380 motors and want to controll
forward/reverse/braking via standard R/C gear.
I've found plenty of designs but they are pretty old and things tend
to evolve quickly.
Specs would be 10-15 amps and 7.2 volts. (I guess)
PIC based is a bonus because I want to be able to delay it bit to
get a more realistic handling.
kufman
I have found a number of ideas on this page
I haven't built any except for the simple servo one.
wovk
What R/C mean exactly?
I found this interresting site... I thinik you have to build an H-Bridge to allow your motor goes foward/braking/reverse
http://www.luxfamily.com/jimlux/robot/picpwm.htm
thay have a sample code in .asm... so you can modify it as your wish... :lol:
you can control the two motors seperatly, so the control will be like a real tank... maybe is what you mean in your message...
if you want to build you own h-bridge, I recommand you to use mosfet cause they are easier to command. I think the bipolar transistors are not a good choice for that kind of application.
