Electronic Dice Project
drunkenmunky
I am doing an electronic dice as a project and i need help.
I want to know how to make a double dice circuit using leds that flash until the dice number has appeared.
Could you please help me because i have no real idea of where to start.
well, i can think of a lor of schematics.....try using a counter set to 6 stages, then use diodes to decode the dice....
or use a counter and 7 segment display.....
the concept is to make a counter wich would go trough the 6 numbers fast enough and stpop it in some position......
if u use 2 dices, make sure not to use the same source for the pulsing signal, if u use 2 oscilators, made from a singe ic, like nand gates or whatever, make them so that they have the frequency a littile differents so they wont sincronize.....
i have some chematics, in case u dont find anything on the net, and anice ting that makes the sound of a dice....
and this i think is the simplest
http://elektronik.kai-uwe-schmidt.de/digital_wuerfel_en.html
hope i helped somehow
@lfcrulez
You're probably not gonna get much response, as this thread is over 8 years old...
