Surfratx138x
Hello
I am a tattoo machine fanatic and armature builder and I wanted to try to get some info about wire gauges on here because a lot of people on here I bet know way more than I do. Just in case you don’t know a tattoo machine is pretty much just an electromagnetic motor.
So the standard wire gauge for the tattoo machines two electromagnets are 24 gauge. I am really wondering why? I have been fascinated by the fact some machines will operate at a lower volt and the only way I’ve found to do that is to have a thicker wire the 22 gauge wire. Are there any drawbacks from using that 22 gauge wire as opposed to the 24 gauge wire that would make the 24 gauge wire the standard. The issue gets more confusing because I was told by an old boss that 26 gauge wire is better because of increased conductivity but when I researched it said the thinner wire will increase resistance and make a weaker magnetic. Some one just posted a machine online though that used a coil core .25 inch shorter than standard cores using the 26 gauge wire that he says hits harder than a normal coil size with the 24 gauge wire. Hoping someone on here has some info for me.
