Electro magnet
jeyes56
Hi, i made an electromagnet to be used as a door lock system, with a core like in the figure shown.
i got a problem, it only produces a very low magnetism,
i don't know much about magnets and designing a core,
please help me to identify what would be the problem in this, or a better design,
this are the parameters:
N=545
V=12v
magnetic wire = AWG #30
I ~= 500mA
Resistance of wire ~= 20 ohms
What material is that core? If you made the top and bottom plates from ferrous material, the magnetic field will take the shortest path from the edges around the top to the bottom instead of out and into some adjoining metal door-strike.
A magnetic system like you are trying to make forms what's called a "magnetic circuit" (google it). The field forming that circuit is what you want going through your door strike.
To do that, I would suggest winding your flat magnet so the poles are at the left and right of the long thin geometry instead of top and bottom. Your core would be a sort of elongated, flat "U" shape (or a "[" shape). Only use the ferrous material in the core (preferably silicon steel, "electrical steel"). If you absolutely have to cover the windings with metal instead of plastic, use nonmagnetic steel or brass.
The strike should bridge the poles of the "U", and complete the magnetic circuit. With that 272 amp-turns of MMF you have it should be a good strong electromagnet.
A good rule of thumb is to make the cross-sectional area of core bigger than the sectional area of the copper (look at the size of the core relative to the amount of copper in a power transformer). Less than that and the B-field will be dominated by the vector potential rather than the M-curve, it's more efficient for an electromagnet to have it the other way around.
And a hot one if you run it for any length of time embedded in a wooden frame - that's 6 watts of heat that has to get out somehow.
Thank you sir,
does it mean that you are suggesting to change my design entirely?
is it better to have the poles on left and right rather than the top and bottom?
i found a magnetic door lock, and i want to imitate it, but i cant its core that's why i came up to this design,
i used a FLAT BAR to construct the above image, is it okay?
here is the image of what i want to imitate:
A flat bar of WHAT?
As I said before, you are building a magnetic circuit. A circuit travels in a loop. A magnetic field travels in a loop. If you insist on doing it top to bottom, at least bring the pole ends from the back around to the front, like they did in that picture you just posted. Otherwise part of the loop is always fringing around the electromagnet through high-reluctance space instead of conducting through the low-reluctance pole pieces and strike.
