Dumb Question from noob: My 9V battery not working?
zef
Hello there everyone,
I am a noob to the world of electronics. I recently bought a multimeter INNOVA 3310 from iEquus. An Energizer 9V battery recently died (it was being used in the personal weighing machine that I have) and I wanted to verify that the voltage was indeed not there. When used my multimeter on it, it gave me a reading of 8.38V. What exactly does this mean? Why was the weighing machine not using this battery? Because it was just a little bit below 9V? Does that mean I can use this battery elsewhere where less than 9V is required or should I just throw the battery away?
It is not about the battery, but about the general concept of non-chargeable batteries if they can be reused even if they fall below their voltage level.
I seek enlightenment :) Any comments will be appreciated.
Zef
Zef
When you measure the battery voltage directly with your meter, without any other load drawing current from the battery it will give you a higher than expected reading. [ the battery is NOT supplying any current to a load]
Place the battery back in the weigh machine and measure the battery voltage while its in the weigh machine.
This will give a 'onload' voltage.. tell us what you read.
If you have any resistors handy you could place a 100R across the battery while you measure the voltage.
Do you follow this.?
My smoke detectors beep when the 9V battery is low. When I measure the battery voltage of a weak one it measures 8.5V even in the smoke detector.
The circuit in the destector applies a load to the battery every few minutes but only for a moment for it to test the loaded voltage of the battery.
A healthy and new 9 Volt battery will have an open terminal voltage of around 9.5 - 9.6 Volts.
