Good-day all,
I am working on a project that interfaces the PIC16f877A and the PC.
Q1) In general, PIC16F877A,the VDD at pin11 and VDD at pin32 are the same, right? [YES/NO]
Q2) when I draw my PCB layout, I draw a connection across the PIC to connect
the pin11 and pin32 together, correct? [YES/NO]
Q3) in my schematic, at each sides of the Vdd, I noticed they are either connected to a capacitor (pin11) or to a parallel-pair of capacitors (pin32), and are then connected to 5V each side.
At pin32, it is connected to the parallel-paired of capacitors and also connected to 5V.
(5V)
(pin32) >>>>>>>* (one end of the parallel-paired capacitor)
(pin31)>>>>>>> * (another end of the parallel-paired cap)
(ground)
my Q3 is
When I draw my PCB Layout, Can I connect the Vdd(pin32) to Vdd (pin11) across the PIC....then I CONNECT the VDD (pin32) to the parallel-paried capcitors ONLY.
My rationale is, when VDD of pin32 connects with VDD of pin11 (by drawing a connection line across PIC16F877a)
VDD of pin32 will also be connected to the 5V that pin11 is connected to.
Is that correct? [yes/no]
OR
I still have to draw Another CONNECTION LINE in my PCB layout...
connecting the
VDD of pin32 + parallel-paired capacitors to the 5V power source?
Please advice.
cheers,
slurp
