Dual Time Digital Clock Problem ? ( its about display )
pasanrobotics
Hey friends I made Dual Time Digital Alarm Clock.
I found it from hamradioindia And its working perfectly with small seven segments. But now I want to connect big jambo size segments.
( I tried some ics to do what i want. like 74HC541 and CMOS 4050. But its not working properly )
Can some one help me plz?:)
hi pasan,
You do not say how you have connected the 541, 4050 or jumbo LED's.
Post a revised drawing with your connections shown.
EricG
I don't really see what you're trying to do?, neither of the chips you mentioned have much output current capability (not really gaining much over the PIC). Either use ULN series drivers, or seperate NPN and PNP transistors - bear in mind you will probably have to invert the software as well.
can u give me some schematics for ULN
Just build a simple buffer like this for every segment of the display.
Why?
I see they're multiplexed but what stops you from using another buffer in series with each bank?
Nigel Goodwin said:
Of course you can, for the ones to ground - the top ones need to be PNP, with the emitter to +ve. Check my tutorial 'Hardware Extras' for examples of sinking and sourcing current.
Thanks again for ur help
Will they turn off with 7.5-12V on the emitter and 5V on the base? My analogue electronics is decidedly rusty.
An NPN transistor turns on when the base is 0.6V about the emitter and a PNP transistor turns on when the base is 0.6V below the emitter.
Ya I checked ur Sinking' current from a lamp. But u cant aply it to this PIC CLOCK project. Coz Anode and Cathodes are driving from PIC. I am confused now:confused:
