hi
i found dspic33fj256gp710 sample codes in assembly,from microchip,
hope will be useful ,turn on led ,with 5 sec delay
.equ __33FJ256GP710, 1
.include "p33FJ256GP710.inc"
;Configuration bits: We will use the MPLAB menu to configure the bits
;Program Specific Constants (literals used in code)
.equ SAMPLES, 64 ;Number of samples
;Global Declarations:
.global _wreg_init ;Provide global scope to _wreg_init routine
;In order to call this routine from a C file,
;place "wreg_init" in an "extern" declaration
;in the C file.
.global __reset ;The label for the first line of code.
.global __T1Interrupt ;Declare Timer 1 ISR name global
;Constants stored in Program space
.section .myconstbuffer, code
.palign 2 ;Align next word stored in Program space to an
;address that is a multiple of 2
ps_coeff:
.hword 0x0002, 0x0003, 0x0005, 0x000A
;Uninitialized variables in X-space in data memory
.section .xbss, bss, xmemory
x_input: .space 2*SAMPLES ;Allocating space (in bytes) to variable.
;Uninitialized variables in Y-space in data memory
.section .ybss, bss, ymemory
y_input: .space 2*SAMPLES
;Uninitialized variables in Near data memory (Lower 8Kb of RAM)
.section .nbss, bss, near
var1: .space 2 ;Example of allocating 1 word of space for
;variable "var1".
;Code Section in Program Memory
.text ;Start of Code section
__reset:
; First initialize the stack pointer and the Stack pointer limit
MOV #__SP_init, W15 ;Initalize the Stack Pointer
MOV #__SPLIM_init, W0 ;Initialize the Stack Pointer Limit Register
MOV W0, SPLIM
NOP ;Add NOP to follow SPLIM initialization
;Next write code to setup the FRC clock to be divided by 256
;7.37 Mhz is thus reduced to 14.3Khz or Tcy = 70 us.
bset CLKDIV,#10
bset CLKDIV,#9
bset CLKDIV,#8
;Next we set PORT A to be a output port
bclr TRISA,#0
; Then light up the LED connected to PORTA bit 0
Again:
bset PORTA,#0
; Add the delay for 0.5 seconds
repeat #7142
nop
bclr PORTA,#0
repeat #7142
nop
bra Again
; Add code to turn off the LED connected to PORTA bit 0
; Copy code written above to delay for 0.5 seconds
; write code to Repeat Loop
done:
BRA done ;Place holder for last line of executed code
;Timer 1 Interrupt Service Routine
;Example context save/restore in the ISR performed using PUSH.D/POP.D
;instruction. The instruction pushes two words W4 and W5 on to the stack on
;entry into ISR and pops the two words back into W4 and W5 on exit from the ISR
__T1Interrupt:
PUSH.D W4 ;Save context using double-word PUSH
;<<insert more user code here>>
BCLR IFS0, #T1IF ;Clear the Timer1 Interrupt flag Status
;bit.
POP.D W4 ;Retrieve context POP-ping from Stack
RETFIE ;Return from Interrupt Service routine
;--------End of All Code Sections ---------------------------------------------
.end ;End of program code in this file
