ds18b20 pic simulator ide problem
wchpikus
Hello!
I'm beginer in programming.
I have some expirence with electronic, but i have problem with software to my board.
PIC 16f874
clock 6Mhz
My connections:
Lcd:
E0-rs
E1-r/w
E2-e
D0 - D7 data to lcd
B1, B2, B3, B4 keys (poolup to vcc)
B7 background led
B6, B5 input (use to swicht)
C7- 1wire to ds18b20
Program:
Define CONF_WORD = 0x3f72
Define CLOCK_FREQUENCY = 6
AllDigital
Define LCD_BITS = 8
Define LCD_DREG = PORTD
Define LCD_DBIT = 0
Define LCD_RSREG = PORTE
Define LCD_RSBIT = 0
Define LCD_RWREG = PORTE
Define LCD_RWBIT = 1
Define LCD_EREG = PORTE
Define LCD_EBIT = 2
Define LCD_READ_BUSY_FLAG = 1
Define 1WIRE_REG = PORTC
Define 1WIRE_BIT = 7
Dim templowbyte As Byte
Dim temphighbyte As Byte
Dim finish As Bit
Dim temp As Byte
Dim sign As Byte
Dim temp2 As Byte
Symbol led = PORTB.7
Symbol key1 = PORTB.0
Symbol key2 = PORTB.1
Symbol key3 = PORTB.2
Symbol key4 = PORTB.3
Lcdinit
TRISB = %00001111 ''''''''''''''''konfiguration Bport
led = 0
main:
''''''''''''''''''''''''''''''''''''''''''''main info
Lcdcmdout LcdClear
Lcdcmdout LcdLine1Home
Lcdout "plytka testowa"
Lcdcmdout LcdLine2Home
Lcdout "klawisze 1,2,3"
If key1 = 0 Then
Goto klawisz1
Endif
If key2 = 0 Then
Goto klawisz2
Endif
If key3 = 0 Then
Goto klawisz3
Endif
If key4 = 0 Then
Goto temperatura
Endif
WaitMs 100
Goto main
'''''''''''''''''''''''''''''''''''''''''''''''''''''ds 1820 (i don't have code here)
temperatura:
Lcdcmdout LcdClear
Lcdout "temperatura"
Lcdout #temp
WaitMs 3
Goto main
koniec
'''''''''''''''''''''''''''''''''''''''''''''''''''key1
klawisz1:
led = 1
Lcdcmdout LcdClear
Lcdout "Klawisz 1"
Lcdout "led on"
led = 1
WaitMs 1
Goto main
'''''''''''''''''''''''''''''''''''''''''''''''''''key2
klawisz2:
led = 0
Lcdcmdout LcdClear
Lcdout "Klawisz 2"
Lcdout "led off"
WaitMs 1
Goto main
klawisz3:'''''''''''''''''''''''''''''''''''''''''''''test key3 to read tem from ds (not working)
ADCON1 = 7
1wireInit
1wireSendByte 0xfe, 0x40, 0x06, 0x09, 0x09, 0x06, 0x00, 0x00, 0x00, 0x00
WaitMs 120
1wireSendByte 0x55, 0x10, 0x31, 0xc5, 0xc8, 0x00, 0x00, 0x00, 0xf4, 0x44
loop:
1wireGetBit finish
WaitMs 25
If finish = 0 Then
Goto loop
1wireSendByte 0x55, 0x10, 0x31, 0xc5, 0xc8, 0x00, 0x00, 0x00, 0xf4, 0xbe
If sign > 0 Then
Lcdout "-"
temp = 255 - temp
temp = temp + 1
Endif
loop:
DS18S20Start
WaitMs 1
DS18S20ReadT temp, sign
temp2 = temp * (1 / 100)
temp = temp2 / 2
Lcdout #temp
If temp2 = 1 Then
Lcdout ".5"
Else
Lcdout ".0"
Endif
Endif
WaitMs 5
Lcdcmdout LcdClear
Lcdout #sign,
Lcdout #temp2
If key1 = 0 Then
Goto main
Endif
Goto klawisz3
'''''''''''''''''''''''''''''''''''''''''''''''''key3
I found some code but it's no working:
loop:
DS18S20Start
WaitMs 1000
Lcdcmdout LcdClear
If sign > 0 Then
Lcdout "-"
temp = 255 - temp
temp = temp + 1
Endif
temp2 = temp.0
temp = temp / 2
Lcdout #temp
If temp2 = 1 Then
Lcdout ".5"
Else
Lcdout ".0"
Endif
WaitMs 500
Goto loop
Could someone help me to start this device?
Regards
WCHPikus
WCHPikus@wp.pl
The DS18s220 code under your key 3 has no chance of working. Swap out with the code listed at the bottom of your post. Better yet, skip the button thing for now and just concentrate on getting the temp code working first.
You may want to try moving your one wire pin to another port pin.
