Does this look like a good soldering station?
gunsmoker
Here's a link to a Pace soldering station on eBay:
How hard would it be to find tips, etc for this one? I want to replace my conventional soldering iron with a soldering station but I'm not sure what brands are the best. Thanks ahead of time.
With $18 shipping cost and you don't get a soldering iron, this is not a good deal.
I did a search for a Weller soldering station & found this one that looks good: **broken link removed**
Bid high, I goes for $144 new.
I bought the Part #229673 soldering station from Jameco at Christmas time and could not be more pleased. However, I notice in the newest catalog www.jameco.com it has gone up to $59.95. Shipping was only another 7 dollars, I think.
The unit you first described has no iron.... the second unit has no control.
Dollar for dollar, I would recommend the Jameco item.
Weller temperature control...........
".... the second unit has no control."
This type of Weller has the control in the tip and handle, you have to have a different tip for each temperature. An elegant solution in my opinion, because when you change temperature you are more than likely to change shape of the tip.
The 700°F tip I use for most of my soldering heats to operating temperature in about 30 sec.!
The model has changed little in the 40 years I have used them, not much to go wrong. The only failure I recalled having was that of the macro switch contacts that I fixed by sanding with a fine emery cloth.
