HiTech
- drug stores had a vacuum tube tester that allowed you to test them yourself?
- the largest parts section in an electronics store was the vacuum tube aisle?
- high voltage putty - used to mend HV leaks in wire insulation in television sets?
- servicing electronic equipment that typically used wax covered or oil filled capacitors and having to deal with the goop that leaked from failed ones?
- having to curse your way through trying to restring a tuner dial and all of those pulleys?
- 8-track audio tapes?
- removing the "metal" rear cover off of a television set to service it?
- when Watts RMS was a measurement term reserved for rating quality audio amplifiers, while the cheap knockoffs were rated using IHF or instantaneous peak specs.?
Post any additional memories you may have of those bygone days!
(and thank God they're bygone! )
