TiagoSilva
Hello guys,
long time no see. First of, glad to see that some old members are still active and in good health.
Now, my one and only multi-meter died, sure I could try to fix it but I would also like to get a new and better one.
Sorry if I should be posting this in "Product & Service Reviews" instead.
So, asides from Fluke and Amprobe (which I would recommend for professional heavy daily activities) not many brands have survived that last 20 years or so.
My question is: Between the UT191E and the UT139S (or even the UT139E) which one do you guys have and recommend (and if not too much trouble why)?
My main usage will be in mostly digital electronics, some analog stuff, also mostly in low power, but I want it to be good enough for me to find issues in cars and general house electrical stuff and appliances and such. I want an digital electronics multi-meter that also works well in the handyman's hands. I came to these 2 models because of the price and general features. I'm leaning to the UT191E (cheaper and sturdier), but the UT139S (look better, has some extra neat features that I will rarely need).
UT191E
Features:
Models and Comparison:
UT139S
Features:
1. True RMS
2. NCV
3. Auto/manual ranges selectable
4. 31-segment analog bar graph
5. Diode, duty ratio and continuity buzzer
6. Black EBTN screen
Thanks in advance!
BR,
Tiago.
UT191E
UNI-T Voltage Meter, Multimeter, Oscilloscope | UNI-T
UT191 Series professional multimeters designed for industrial users This CE GS cTUVus certified multimeter series co
www.uni-trend.com
Features:
- Measurement setting saved after power reset
- IP65, 2m drop proof
- True RMS/Peak value measurement
- Auto backlight
- 20A current measurement
- LoZ AC measurement
Specifications | Range | UT191E | UT191T |
DC voltage (V) | 600V | ±(0.5%+3) | ±(0.5%+3) |
AC voltage (V) | 600V | ±(0.7%+3) | ±(0.7%+3) |
LoZ ACV (V) | 600V | ±(2%+5) | ±(2%+5) |
ACV LPF | 600V | ±(2%+5) | ±(2%+5) |
DC current (A) | 20A | ±(0.8%+3) | ±(0.8%+3) |
AC current (A) | 20A | ±(1%+3) | ±(1%+3) |
Resistance (Ω) | 60MΩ | ±(0.8%+2) | ±(0.8%+2) |
Capacitance (F) | 60mF | ±(3%+5) | ±(3%+5) |
Frequency (Hz) | 10Hz~1MHz | ±(0.1%+4) | ±(0.1%+4) |
Duty cycle | 0.1%~99.9% | ±(2%+5) | ±(2%+5) |
Temperature (℃) | -40℃~400℃ (0.1°C resolution) | ±(1%+20) | |
Temperature (℉) | -40℉~752℉ (0.2°F resolution) | ±(1%+40) | |
ACV peak hold | ±(2%+100) | ±(2%+100) | |
Peak current detection | ±(3%+100) | ±(3%+100) | |
Features | |||
Display count | 6000 | ||
Sampling rate | 3 times/second | ||
Analog bar graph | 31 sections | ||
True RMS | √ | ||
AC voltage frequency response | 45Hz~400Hz | ||
AC current frequency response | 45Hz~400Hz | ||
Diode/Continunity test | √ | ||
Auto/Manual range | √ | ||
Auto power off | √ | ||
Low battery indication | √ | ||
Data hold/MAX/MIN | √ | ||
Function selection (SELECT) | √ | ||
Flashlight/Auto backlight | √ | ||
2m drop test/IP65 | √ | ||
General Characteristics | |||
Power | 9V battery | ||
LCD size | 58mm x 42mm | ||
Product net weight | Red and grey | ||
Product color | 428g | ||
Product size | 180mm x 87mm x 59mm | ||
Standard accessories | Test lead, battery, carrying bag, point contact temperature probe (UT191T) | ||
Standard individual packing | Gift box, English manual | ||
Standard quantity per carton | 10pcs | ||
Standard carton measurement | 545mm x 315mm x 335mm | ||
Standard carton gross weight | 8.8kg |
UT139S
Features:
1. True RMS
2. NCV
Specifications | Range | UT139A | UT139B | UT139C | UT139E | UT139S |
DC voltage (V) | 600V | ±(0.5%+2) | ±(0.5%+2) | ±(0.5%+2) | ±(0.5%+2) | ±(0.5%+2) |
AC voltage (V) | 600V | ±(1%+3) | ±(0.8%+3) | ±(0.8%+3) | ±(0.8%+3) | ±(0.8%+3) |
DC current (A) | 10A | ± (0.7%+2) | ±(0.7%+2) | ±(0.7%+2) | ±(0.7%+2) | ±(0.7%+2) |
AC current (A) | 10A | ±(1%+3) | ±(1%+3) | ±(1%+3) | ±(1%+3) | ±(1%+3) |
Resistance (Ω) | 20MΩ | ±(1%+2) | ||||
40MΩ | ±(0.8%+2) | |||||
60MΩ | ±(0.8%+2) | ±(0.8%+2) | ±(0.8%+2) | |||
Capacitance (F) | 99.99mF | ±(4%+5) | ±(4%+5) | ±(4%+5) | ±(4%+5) | |
Frequency (Hz) | 10Hz~10MHz | ±(0.1%+4) | ±(0.1%+4) | ±(0.1%+4) | ±(0.1%+4) | |
Temperature (°C) | -40°C~1000°C | ±(1%+3) | ±(1%+4) | ±(1%+4) | ||
Temperature (°F) | -40°F~1832°F | ±(1.5%+5) | ±(1.5%+5) | ±(1.5%+5) | ||
Features | ||||||
Display count | 2000 | 4000 | 6000 | 6000 | 6000 | |
Auto range/Manual range /True RMS | √ | √ | √ | √ | √ | |
Bandwidth (Hz) | 45Hz~400Hz | 45Hz~1kHz | 45Hz~1kHz | 45Hz~400Hz | 45Hz~400Hz | |
NCV/Continuity buzzer | √ | √ | √ | √ | √ | |
Duty cycle | 0.1%~99.9% | √ | √ | √ | √ | |
Diode | Around 2V | Around 3V | Around 3V | Around 3V | Around 3V | |
LPF/LoZ (ACV) | √ | √ | ||||
Analog bar | √ | √ | ||||
General Characteristics | ||||||
Power | 1.5V battery (R6) x 2 | |||||
Display | 58mm x 36mm | |||||
Product color | Red and grey | |||||
Product net weight | UT139A/B/C: 354g; UT139E/S: 345g | |||||
Product size | 170mm x 80mm x 48mm | |||||
Standard accessories | UT139A/B: Batteries, test leads; UT139C/E/S: Batteries, test leads, temperature probe | |||||
Standard individual packing | Gift box, English manual | |||||
Standard quantity per carton | 20pcs | |||||
Standard carton measurement | 450mm x 330mm x 340mm | |||||
Standard carton gross weight | 12.2kg | |||||
Optional accessory | UT139C: Current sensor AC/DC 40A |
Thanks in advance!
BR,
Tiago.
