Displaying ADC result on GLCD with C18
superbrew
Hello, I would like to display the result of an ADC conversion on my GLCD, but all I am getting is about 2.5 lines of garbage. Here is the code that I am using:
(GLCD functions created by Pommie and modified for my use)
#include <p18f2520.h>
#include <GLCD.h>
#include <adc.h>
#include <delays.h>
#include <stdlib.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO67
void main (void){
	int read;
	char adc_ret[10];
	ADCON1 = 0x0d;
	CMCON = 0x07;		// no comparators
	OSCCON = 0x70;
	TRISA = 0XFF;
	TRISC = 0x00;
	//Setup
	Init_GLCD();
	OpenADC(ADC_FOSC_RC & ADC_LEFT_JUST & ADC_12_TAD,
		ADC_CH1 & ADC_INT_OFF & ADC_VREFPLUS_VDD &
			ADC_VREFMINUS_VSS, 13);
	SetChanADC( ADC_CH1 );
	PutMessage((rom char*)"test");
	Delay10KTCYx(200);
	while (1){
		ConvertADC(); // Start conversion
		while( BusyADC() ); // Wait for completion
		read = 523;ReadADC();
		itoa(read,adc_ret);
		PutMessage((rom char*)adc_ret);
		Delay10KTCYx(250);
		SetPos(0,0);
        //This section of code works, I used it check ADC function
	/*ConvertADC();
	while(BusyADC());
	i = ReadADC();
	if(i<125)PORTC = 0b00000001;
	else if(i>126 && i<250)PORTC = 0b00000011;
	else if(i>251 && i<375)PORTC = 0b00000011;
	else if(i>376 && i<400)PORTC = 0b00000111;
	else if(i>401 && i<525)PORTC = 0b00001111;
	else if(i>526 && i<650)PORTC = 0b00011111;
	else if(i>651 && i<750)PORTC = 0b00111111;
	else if(i>751 && i<875)PORTC = 0b01111111;
	else if(i>876 && i<1023)PORTC = 0b11111111;
Stepping through using MPLAB simulator, it seems to get hung up at the itoa function. Thanks
Your problem is due to pointer differences. PutMessage expects a pointer to a rom string and you are passing it a ram variable.
You can get it working by doing,
    while (1){
        itoa(read,adc_ret);
        pos=0;
        while(adc_ret[pos])
            PutChar(adc_ret[pos++]);
        Delay10KTCYx(250);
        SetPos(0,0);
Not very elegant, but should work. Someday soon I'll get around to tidying those GLCD routines.
It works! Thanks again. Now I just have to figure out how to get the numbers on the display to be right justified.
How about,
    while (1){
        itoa(read,adc_ret);
        [COLOR="Blue"]SetPos(0,16-strlen(adc_ret));[/COLOR]
        pos=0;
        while(adc_ret[pos])
        Delay10KTCYx(250);
        SetPos(0,0);
Edit, forgot this was for a GLCD. The above is for a 16 character LCD. The principle is the same but it will be 128-strlen(adc_ret)*charwidth.
Glcd
hi, I neede the GLCD functions, please please tell me where I can find it or help me
thank you
Glcd
I can´t open the demo...I try to open but I can´t.... it s a not found page.....
Please help me with that I need the glcd libaries...How can I acces them..
thank you
In the microcontroller forum look for the thread Unicorn-GLCD-Demo. Al the code is in that thread.
