display temperature, voltage and current
stereovestro
i have LM35 and would like to display temperature on the LCD. im able to display current and voltage using ADC with pic18f4520.
on the LCD, it displays voltage and current. how can i blank the lcd, put 0.5sec delay and display temperature using LM35 without interrupting the ADC(analogue to digital conversion)?
thanks.
The ADC works in hardware so once you start it, you can do whatever else you like until it indicates that the conversion has completed.
If you are using the polling method, then it will wait until you get around to reading the value, so if there are delays elsewhere before you check the "DONE" flag it should not really matter.
If you are using the interrupt method, then as long as your delay in software then the interrupt will just be called when it need to be. If you are using multiple interrupts, then you will need to either allow for nested interrupts or be ready to have the interrupt hander called again as soon as it has finished the first interrupt.
Susan
thanks.
can u proveid to display current and voltage using ADC with pic 16f676 \72 lcd\ 7 segment display
