Ok so i gotta redo the partition on the HD and create one with FAT16 if i want to use 6.x ..in logical drive C spot..Joel Rainville said:DOS doesn't want the whole drive, it wants to be in the first primary partition of your hard disk. If your first partition (what Windows XP shows you as C: ) isn't FAT16, you're screwed, assuming you are using an actual DOS version 6.x and earlier.
Starting with DOS 7 (what comes with Windows 95 that can actually be used as a standalone DOS more or less successfully), you could use FAT32 on your primary partition.
But judging from the minimal details you give in your post, it looks like you are trying to use a DOS 6.x or earlier on a hard disk with a primary partition in FAT32. This is a no-go.
williB said:Ok so i gotta redo the partition on the HD and create one with FAT16 if i want to use 6.x ..in logical drive C spot..Joel Rainville said:DOS doesn't want the whole drive, it wants to be in the first primary partition of your hard disk. If your first partition (what Windows XP shows you as C: ) isn't FAT16, you're screwed, assuming you are using an actual DOS version 6.x and earlier.
and use FAT32 if i want to use 7.x ??
thanks![]()
No i didnt know that the first partition had to be DOS..But judging from the minimal details you give in your post, it looks like you are trying to use a DOS 6.x or earlier on a hard disk with a primary partition in FAT32. This is a no-go.
ok Here is the dealy..Joel Rainville said:Of course, XP won't erase itself.
You basically have 2 options if you want to install Dos 6.x :
- kiss your current XP installation goodbye, boot from a DOS bootdisk and run fdisk to partition your hardrive.
- reinstall XP and specify a FAT16 filesystem for c:\
Is your current C:\ FAT32 or NTFS? If it's FAT32, you could avoid losing your XP installation by using DOS 7 on it.
What do you need DOS for exactly? In some circumstances, DOS 7 just won't do it...
williB said:ok Here is the dealy..Joel Rainville said:Of course, XP won't erase itself.
I am setting up a box to run Autocad & My Pic Programmer ( which uses turbo pascal) --both run on DOS ..
and i thought that having XP on there also i could transfer files to both pgms easier.. :wink:
TekNoir said:I have a very cheap secondary harddrive loaded with DOS 6.22 and run a bootloader to accomplish this.
Q 1 : correct..i've allready loaded it in twice.. :lol:Joel Rainville said:williB said:ok Here is the dealy..Joel Rainville said:Of course, XP won't erase itself.
Ok, so you don't mind wiping XP and starting from sratch, right?
Do you have a DOS bootdisk? Are you comfortable running fdisk under DOS to partition your drive?
i've got oodles of drives floating around here...Joel Rainville said:TekNoir said:I have a very cheap secondary harddrive loaded with DOS 6.22 and run a bootloader to accomplish this.
Yeah, that would work, even with XP's bootloader. But you need a second drive![]()
williB said:i've got oodles of drives floating around here...Joel Rainville said:TekNoir said:I have a very cheap secondary harddrive loaded with DOS 6.22 and run a bootloader to accomplish this.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINXP
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINXP="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
multi(0)disk(1)rdisk(0)partition(1)\="DOS 6.22"
TekNoir said:All the info you could want for WindowsXP boot.ini file -- https://support.microsoft.com/default.aspx?scid=kb;en-us;289022#XSLTH4157121122120121120120
