Discrete NAND Synthesizer Help
Hello Dear Friends, please I was given an assignment to design an 8-bit counter, 7-segment display with given components; TTL 7400N, 7493N family, power source, etc.
We were actually instructed to design and simulate with Electronic Workbench (Multism).
Please, I really need help.
Thanks,
Outlook101
Have you:-
1. read the data sheets of the 7400N, 7493N?
2. done a search in this forum for "counters?
There have been many posts of counter circuits in the past.
You won't learn much if we do it for you.
Interesting. I don't use a lot of CD4000 series, but I do know all the AC ACT HC etc that I regularly use have quite reliable switching points and hysteresis.
I also have doubts about your first transfer chart for the 4011B, where is it from? I've NEVER seen CMOS gate inputs that had zero hysteresis as shown. Hook one up with a pot on the input and you should see a very obvious hysteresis right around the expected voltages.
From my databook;
BU4011B 1.5 3.5
CD4011B 1.5 3.5
CD4011AE 1.5 3.5
HCC4011BK 1.5 3.5
out of 40 brands and specs listed fo the 4011 there are only about 6 that list 1.0 and 4.0v, the rest are 2.5 and 3.5 which are about the values you always see when testing the real chips.
Now the schmidt version;
BU4093B 1.5 3.5
MC14093BAL 1.5 3.5
again almost all are listed as 1.5v and 3.5v respectively.
It's been a lot of years since I tested a CMOS chip that did not have a large input hysteresis and quite relaible LO and HI threshold voltages. But maybe there are still some crap manufacturers that can't design a CMOS input pin circuit. Can you suggest a brand or chip I can test??
You can test any reliable brand of CD4000 parts. I believe that Fairchild, TI, and NXP (HEF series) are still in production. You might find new old stock of National, Harris, Intersil, Motorola, and ON Semi. There are probably others.
While you're at it, test some 74HC/HCT gates. As I said earlier, 74HC14 and 74HC132 are the only SSI parts in that series with Schmitt trigger inputs.
A simple test is to enable the (inverting) gate by connecting all but one input to the appropriate rail, then feed a 1 Meg resistor from the output to the remaining input, and a 100nF (or whatever) from the input to GND If the input has hysteresis, you will get a square wave on the output and a triangle wave on the input. If the input does not have hysteresis, the input will be biased at the input logic threshold (due to the negative feedback), as will the output, except the output may have a lot of noise on it.
I ran this test on 3 different gates. Vcc was 5.00V in all three cases. Results were as follows:
1. An HCF4011 quad NAND made by ST Microelectronics. Vin=2.63V, Vout=2.63V (with about 4.5V volts p-p of noise)
2. A 74HCT00 quad NAND made by RCA. Vin=1.40V, Vout=1.40V (with about 800mV p-p of noise)
3. A 74HC132 quad NAND with Schmitt trigger inputs, made by Philips. Vin was a triangle wave swinging between 1.8V and 2.5V at about 18Hz. Vout was a square wave at the same frequency.
You can't run this test on noninverting gates (OR, AND, noninverting buffer), because the resulting positive feedback will put both input and output at one of the rails.
Think about this: If all gates had Schmitt trigger inputs, why would only 2 in each family explicitly mention this?
Roman, you are misinterpreting the input specs in the datasheets.
Roman, you are wrong.
An ordinary CD4001 or CD4011 Cmos gate has no hysteresis. With a 5V supply its switching threshold input voltage is anywhere from 1.5V to 3.5V.
Ordinary 74HCxxx high speed Cmos gates are the same. 74HCTxxx gates have a TTL input range of voltages.
That is why an inverting gate can be used with a negative feedback resistor to make a linear amplifier. An inverting gate with a Schmitt trigger input cannot be a linear amplifier because the hysteresis will make its output latch.
It's about time someone spoke up to back me up. I was startin' to feel like the Lone Stranger!:D
Interesting test results. I have often used a spare gate in a circuit to make reliable oscillators with AC HC and HCT type gates and usually got results similar to what you say for test 3. Are your results from a simulator or actual chips?
No I understand that the datasheets results are for min max and the switching occurs at some point (or 2 points) between. I was mainly poiting out that the datasheet lists the spec as 1.5v 3.5v for the actual schmidt version 4093 and also lists 1.5v 3.5v for most of the standard CMOS chips.
Anyway I'm not going to fly in the face of public opinion and I do apologise for my posts sounding argumentative. My original remark was in regards to making an audio freq oscillator from a CMOS gate, which is something I have done often and which usually works well with modern CMOS chips. As far as what brands of chips, what series and which chips have hysteresis and how much hysteresis they have I'll leave that up to the chip manufacturers. My apologies people for derailing the OP's thread. :)
