Disable timer1 if RB4-RB4 change occurs (IOC) when device is in INT0 intterupt loop
softlab
Dear All,
I have to ON GREEN LED if interrupt occurs on RB4-RB7 pins (IOC). Next, If Interrupt occurs (INT0) while GREEN LED is ON, RED LED should be ON for 5 minutes and then OFF. If again interrupt occurs on RB4-RB7 pins (IOC) while RED LED is ON, I have to switch off RED LED immediately. I have used timer1. Everything works fine except switch OFF the RED LED. I could not able to read interrupt on RB4-RB7 pins (IOC) while timer1 runs. Any help pl?. The following is the code:
 void interrupt isr(void){
     if (INTE && INTF) {
     delay_ms(10);
        if(RB0 == 0){
             if (LED == 1){
                 LED = 0;
                 ALARM = 1;
                 T1CON=0b00000001;
                 while (1){
                        while (! TMR1IF);
                        TMR1IF = 0;
                        count ++;
                        if (count == 75){
                            count = 0;  // Reset Counter
                            ALARM = 0;  // OFF the Alarm
                            TMR1IF = 0; // Clear Timer Flag
                            TMR1IE = 0; //disable timer1
                           break;
               //delay_5min();
               //       ALARM = 0;
     INTF = 0;
     INTE = 1;
    if(RBIE && RBIF){
       delay_ms(10);
       if(RB4 == 1){
           RBIE = 0;
           if (ALARM == 1){
           else{
                if(LED == 1){
                   LED = 0;
                   beep_Off();
                else{
                     LED = 1;
                     beep_On();
                     for(i=0;i<150;i++){
                         for(j=0;j<150;j++);
                     beep_On();
      mismatch_Clr = PORTB;
      RBIF = 0;
      RBIE = 1;
 SLEEP();
