There are a lot of misconceptions in this thread, I'll try to clear a few things up:
Charge carriers can be positive or negative. In almost all electronics, these will be electrons in solid metal wires and semiconductors. They flow from high negative potential to low negative potential (ie. negative to positive).
In chemistry, you come across redox reactions. In liquid aqueous solutions, there will be positive ions which flow from positive to negative - the opposite direction to electrons. A simple example would be saltwater, where Na+ flows one way, while Cl- flows the other.
The reason we still use conventional current is because the idea of positive charges wasn't entirely incorrect - you can have positive charges (eg ions in solution). That, and the fact that all schematic symbols were drawn in the conventional current direction - diodes, NPN/PNP transistors, etc. The important thing is that polarity is defined and kept consistent. As long as you connect + to + and - to -, the actual current direction is irrelevant.
A battery or a capacitor doesn't store charges, nor do they store electrons. They store ENERGY. The misnomer comes from the two meanings of the word charge - yes they are "charged" with energy, but you do not fill them up with charges (eg electrons or positive ions). The net amount of electrons in a battery or capacitor is the same whether charged or discharged. (Here's a good explanation/analogy of capacitors.)
That's because it isn't true.
A battery is comprised of 2 metals/substances - one that naturally oxidises, while the other naturally reduces. The oxidising substance loses electrons, while the reducing substance gains electrons. The substance which loses electrons becomes the negative terminal. These electrons flow out through an external circuit and back through into the positive terminal, reducing the other substance.
The Voltaic Pile is probably the simplest to understand. Zinc corrodes (oxidises) more readily than copper, so it will become the negative terminal, giving off electrons, which travel through a circuit and back to the copper, which reduces as it receives electrons.
Edit: Something else that might help you visualise what "conventional current" is in solid wires and semiconductors:
Imagine a group of people standing in a circle, where everyone has a ball, except one person. Each person passes their ball clockwise. However, the "hole", ie. the person who doesn't have a ball will appear to move anticlockwise. The balls are your electrons, and the absence of an electron is your conventional current flow. This is the principle of "hole charge carriers" in semiconductors.
???The majority of the human race does not know that the positive terminal of a battery is actually the source of negative particles.
