Dipole antenna
Looks fine to me, no need for balun.
Russlk said:
You don't need a balun, that is the beauty of this design. Are you getting good reception?
Yes, the reception is great compared to the 22" wire I had mounted on the radio.I am hearing almost continuous airtraffic now. But I also hear some FM stations in a couple of spots on the dial ( very low ,but there) which I dont want:rolleyes:. But thats the receivers fault I guess. I am very happy with the radio/ power supply and antenna and have learned alot from this project.
Thanks sam
Sounds like poor image rejection from a badly designed (or cheap) radio.
Well Nigel, you did describe it as fairly simple and crude;) but its a start.
I am just happy that it works as well as it does.
Electronics is the most amazing and fun thing.
Thanks,sam
It's not simple to design a radio for good image rejection, the simple design you built only uses a bandpass filter - using a proper tuned input stage (or two) would greatly improve image rejection.
One thought?, have you got it mounted in a screened metal box?, if not it may be picking up strong FM stations directly rather than through the aerial.
Nigel, or anyone ealse, what could I do to the receiver to remove those unwanted FM stations?
Thanks, sam
Thanks Nigel, you answerd my question before I asked it.
Sam
No , its in a plastic project box. I have a metal box , but what is a screened metal box?
Once you have this working well, you might be interested in picking up Weather Satellite images at 137.62 MHz or 137.5 MHz. Many amateurs do this and there are lots of websites showing how. You end up with weather satellite photos on your PC. Cool.
Here's one information link:
https://www.hobbyspace.com/Radio/index.html#WeatherSat
scroll down to the heading "Image Reception from
Weather and Other Satellites ".
I got rid of 99% of the FM station noise by turning the slug down in the coil( local oscillator coil) .At full volume I can just barely hear something at one end of the dial. I will try a metal box next.
Thanks, sam
Sam
It's fully sealed all the way round, and connected to the ground of the PCB - the only way signals can get to the board is then via the aerial socket.
You might be able to purchase an FM broadcast filter that is designed to attenuate FM broadcast but pass frequencies above and below. You'd want to understand the cutoff frequency. I'd google on FM broadcast trap or FM broadcast filter for more detail. This would be done in addition to the sheilding.
Can this be made by shielding a box using alluminum foil?
I built a FM band stop filter I found on line and put the power supply and radio in a aluminum box and no more fm noise, and what static there was is very quite now. I dont even have to use the squelch.
It worked great at home but when I set it up at school( inside a metal hanger with a half wave dipole on the roof) I get the AWOS (atomated weather observing system) signal so strong that I can hear it three places on the dial and it blocks out most of the aircraft transmissions.
The AWOS transmitter is only about 200 yards away.
Can I build a filter that would block out just that( 134.75Mhz)frequency. It would be ok to block it out and above, because it is at the very top of the frequencies I want to hear. I can follow a schematic, but dont have any experience designing. Would a stub filter work?
Thanks, sam
