Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
It is not normally recommended that diodes be operated in parallel because each diode turns on at a slightly different forward voltage meaning that one diode may end up taking the brunt of the load. Series-connected rectifiers are common, especially in high-voltage circuits. The ARRL Radio Amateurs Handbook, especially the older ones from the 1960's and 1970's have excellent examples of these in their transmitter and linear ampifier power supplies. Usually, each diode is in parallel with a small (0.01µF) ceramic capacitor and a high-value (100K-1M ohm) resistor. The resistor equalizes the reverse voltage across the diodes so that one that has a higher reverse resistance isn't overstressed and the caps serve to bypass transients that could kill the rectifier.
The voltage rating of the series rectifier stack will be the sum of the rating of the individual diodes (the diodes should be identical!) and the current rating is that of an individual diode.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
